Plugin 78 Camper special
Old Apr 3, 2004 | 08:48 PM
BC78ford's Avatar
BC78ford
I took the box off my 1978 Super Camper Special and mounted on the top side of the frame on the drivers side is a plugin?
It looks like a stock mounting and the wiring seems to go into the taillight harrness.
Would it be a plugin for a camper ?
Old Apr 3, 2004 | 08:54 PM
Mil1ion's Avatar
Mil1ion
Well the topper wiring runs along the frame & comes up behind the cab on the driver's side.
It is combo 1 male/ 1 female plug
Old Apr 3, 2004 | 10:07 PM
BC78ford's Avatar
BC78ford
Its a flat plug with 5 female and 1 male.
Kinda looks like one of those little flat trailer plugs.
Its got a bolt through it securing it to the top of the frame.
Its bolted on the top of the frame about a foot behind the cab on the drivers side.
Old Apr 3, 2004 | 10:37 PM
Mil1ion's Avatar
Mil1ion
You win ... .Camper wiring
Old Apr 3, 2004 | 11:10 PM
BC78ford's Avatar
BC78ford
Would that be stock?
Or someone added it?
Its a long ways from being able to plugin to anything without a long jumper wire?
Old Apr 4, 2004 | 12:38 AM
Stephen Kennard's Avatar
Stephen Kennard
factory wiring plug 78 camper special
yes...the plug you found is a factory plug...The other end of the harness would have been found in the glove box when the truck was purchased. it is for a slide in camper or a fifth wheel trailer.. you would plug into the wiring harness via the junction you found then ..wire the "loose" end into whatever camper loom that came with the camper/trailer....then when you drop your camper/ trailer you just unplug from the spot you found leaving the loom on your camper/trailer for easy "hook n book" next time your ready to go.
Old Apr 4, 2004 | 03:19 PM
BC78ford's Avatar
BC78ford
Thanks for the info guys.
