Sponsored by: Real Truck
Speed Limiter?
Old Apr 3, 2004 | 08:42 PM
CruisnPhantom's Avatar
CruisnPhantom
Question Speed Limiter?
I've got a 2004 Ford F-250, Harley Davidson 6.0L Crew Cab, and I am wondering about the speed limiter...I understand I might get flamed because somebody already took this personally but I would like to know.
About two months ago I hit 100MPH, so I asked around and was told the limiter won't let you go that high. So I say "Ok, speedometer error" so it must be off, right?
Not two hours ago did I hit 103MPH. I've been told these are limited to 90? 95? Why did I hit 103? The H.D. truck's speedo goes all the way to 110MPH. When I hit 103 there was no unusual noises or sputtering of the engine so it couldn't have been getting limited at that speed. I let off the gas, it was still going to rise up.
Don't take this personally, guys! I'm just the middle man between the speedometer and you.
Old Apr 3, 2004 | 08:51 PM
nafzimo's Avatar
nafzimo
Chipped? Downhill? Mine won't go faster than 97.
Old Apr 3, 2004 | 08:55 PM
CruisnPhantom
that is the strange thing, unless window tints and a trailer brake controller make me go faster
Old Apr 3, 2004 | 09:21 PM
brwolfjr's Avatar
brwolfjr
maybe ford does not have a limiter on the trucks with 18" wheels. That is just a guess. Mine cuts at 95.
Old Apr 3, 2004 | 11:58 PM
bdjupiter's Avatar
bdjupiter
My 2000 5.4 used to cut out at 90 until I got a chip. Now I'll just say it will go above that nicely.
Old Apr 4, 2004 | 12:06 AM
mbnv992's Avatar
mbnv992
The speed limiter on the SD's is at 98 MPH. Your HD's speed limiter must be set at a higher speed (like 105 maybe?) but you should still have one. Before I got my chip, my truck would always cut out at around 100MPH or so. Now, it goes past that, (110 maybe ? ) then it goes around in circles (when going 125+) I wish they made these trucks with speed markings past 100 MPH
Old Apr 4, 2004 | 05:53 AM
Autobahn F-250 Lariat's Avatar
My 2002 limits out at 98mph I know this well living here in Germany and driving the autobahn daily
Manny
Old Apr 4, 2004 | 07:04 AM
unit5alive's Avatar
unit5alive
Could the speed rating on the tires be higher? some vehicles are top speed limited by the rating on the tire.
Old Apr 4, 2004 | 12:06 PM
majorpecs's Avatar
majorpecs
My speed limiter used to kick in at 94mph....BUT now all i get is the check engine light since my superchips tuner raised the limiter I've not yet had the limiter kick in....
Old Apr 4, 2004 | 12:48 PM
daimon1054's Avatar
daimon1054
The old trucks used to be set at 99, not sure what they are now. But your speedo is not spot on, I run my GPS and the faster I go the more off the speedo is. At 60 I am spot on at 65 1 mph off by 85 I am showing 85 on the speedo but 82 on the GPS so you might be reading faster than you are going.
Last my brother and I had the same truck and he was a good bit faster than I was so not all speed limiters are created = some will get a few mph more.
Old Apr 4, 2004 | 05:44 PM
LOOnatic's Avatar
LOOnatic
FYI:
I came across a de-limiter on the bd-power.com website.
Same guys as the Edge-Juice-Lightning products.
Just passing it along......
Old Apr 4, 2004 | 06:39 PM
jdadamsjr's Avatar
jdadamsjr
I would imagine the speefd limiter is based on the lowest common denominator...
If the tires are not speed rated for more than xxx mph, then the truck is probably set at xxx-5 mph or something like that...
The predator for the 6-oh REMOVES the speed limiter...
I know it does
Old Apr 5, 2004 | 01:31 AM
68 351 bronc's Avatar
68 351 bronc
My 2001 SD won't go faster than 97. I don't feel any jerking or spluttering, it just won't go any faster. The computer won't let it have more fuel?
Old Apr 5, 2004 | 04:06 AM
Connect's Avatar
Connect
Not sure how it works, but yes all trucks do have a speed limiter, the HD's is either set higher or on the lightning and hd its off possibly. Im scared to push my truck to the redline with my large tires
A chip is designed to do just that, rewrite the computer so it delimits (most do anyway) and sends more fuel/air. Personally i cant see a hd doing 125 unless its lowered or something, hope you dont hit a chevy geo doing that, youll take the top of the car clean off.
Personally if your gonna spend 45+k on a truck, just get a dodge ram srt10 man, **** thats a truck
Flame away, i like dodges
Old Apr 5, 2004 | 07:14 AM
majorpecs's Avatar
majorpecs
Then go get on a dodge board....wtf
