Sponsored by: Kumho
Replacing Front Brake lines
Old Apr 3, 2004 | 03:04 PM
nautikal2k3's Avatar
nautikal2k3
Arrow Replacing Front Brake lines
I am new at working on brakes and I need a little help. I have a '74 f100 that I tried to get inspected here recently, however, they wouldn't pass it due to a small hair-line crack in my left front brake hose. They wanted to charge $80 to fix....so I will do what most country boys will do, attempt to fix it myself. Is it a hard job? I heard that you have to have special brake tools. Any help will greatly be appreciated. Thanks, Jason
Old Apr 3, 2004 | 09:41 PM
hdgapeach's Avatar
hdgapeach
It helps to use line wrenches. They help prevent rounding the corners on the line fittings. Go to the parts house and get (or order) a new line and a bottle of the correct brake fluid and change the line and bleed the brakes. If one line is bad I would check the others as well.
Old Apr 4, 2004 | 12:30 AM
nautikal2k3
Thank you. Does it usually take two people to bleed the brakes or can it be done by myself?
Old Apr 4, 2004 | 09:42 AM
hdgapeach's Avatar
hdgapeach
Faster, easier, and cheaper with two people. You'll need a vacuum pump or a pressure bleeder if you do it by yourself.
Old Apr 4, 2004 | 09:54 PM
rebocardo's Avatar
rebocardo
For 2x4, you can buy hoses pre made. If you have to make your own hose, 4x4, then order it from the NAPA hydraulic catalog. I made my own, for more info search the 1967-1972 forum using "hoses F-100 napa" for the part numbers, that should bring it up.
Get brand name flare nut wrenches. A good wrench can make the difference between a saved fitting or a rounded off one. When loosening an old bleeder value, use some WD-40 and a socket. THEN use a bleeder wrench to tighten/loosen as you bleed the brakes.
Bastin
May 20, 2017 01:44 PM
darrowj
Aug 27, 2016 12:45 AM
arkredneck
1978 - 1996 Big Bronco
Nov 24, 2015 02:11 PM
cbjr61
Sep 21, 2007 05:33 PM
u31geb
16
May 19, 2006 08:22 PM
