Aftermarket Products
Sponsored by: Worksport
electric fans
Old Jun 29, 2004 | 08:38 AM
Commo's Avatar
Commo
Just curious, but if electric fans are such a winner why aren't they either an option or standard on vehicles? My VTX1300 has one but its a motorcycle.
Old Jun 29, 2004 | 09:39 AM
94F150-408's Avatar
94F150-408
Its really a cost issue, they are considerably morre expensive than a fan/cluth set up.
Old Jun 29, 2004 | 05:53 PM
rebturtle's Avatar
rebturtle
I agree, the automakers aren't going to go to all the trouble of changing their design to save the customer 5 HP if it costs an extra $10/ vehicle. If you want a cheaper option, by the way, head to a wrecking yard and remove the entire fan & shroud assembly from a front-wheel drive car that will fit your radiator. It'll probably cost you one-third that of an aftermarket one from the parts store.
.....Could you imagine a crankshaft-mounted fan on a motorcycle? It would keep your leg cool at least, since it too is tranversely mounted.....
Old Jun 29, 2004 | 07:28 PM
351M's Avatar
351M
2 Speed Electric fans from a Dodge Viper are a good way to go, or so I am told, wire it for low speed as needed while driving with no A/C and have it kick on High speed when the A/C is on.
Old Jun 29, 2004 | 07:45 PM
Torque1st's Avatar
Torque1st
Posting Legend
Actually the OEM's would jump on 5HP for $10. Electric fans are only more efficient if they are computer controlled. They are great if you are drag racing or in water crossings because you can turn them off during the run or while in the water. Otherwise they are complex and prone to failure. Many aftermarket units have very poor mounting methods. OEM wiring is usually OK but the aftermarket wiring is sub-standard. Claims of 10+ HP gains are off-base because it takes very few HP to drive the stock clutch fan.
Old Jul 26, 2004 | 09:34 PM
claynewt's Avatar
claynewt
Read "Sport Truck" mag. article on an f150 install w/ Flex-a-lite #270. They dynoed before and after and found about 10 hp. Their overall impression was pretty good.
BTW i think it was from a couple or three months ago. I'll get back.
Old Jul 26, 2004 | 10:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
Yeah, but like I said they are not getting the true HP figures for real life driving. You just can't get that on a stationary dyno during the few seconds of a dyno run. Flex-a-lite probably "sponsored" that tech article. There are many of those in magazines. Take anything they say with that big lump of salt. They are there to sell product and empty your wallet.
Old Aug 4, 2004 | 08:29 PM
nemesis500548's Avatar
nemesis500548
How about this. A new dual electric fan setup is running about $400, and a single fan universal is about $100. Am I correct in supposing that the single electric fan will operate sufficiently enough to keep the engine cool since the stock mounted fan is a single fan, or do they not flow enough air and the dual fan should be used?
Old Aug 4, 2004 | 09:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Most single fan setups will not draw thru the entire radiator and will not produce enuf cooling.
Old Aug 4, 2004 | 09:27 PM
rebturtle's Avatar
rebturtle
It depends on the size of the fan, and how much cooling you need. Since a radiator is somewhat rectangular, a dual setup can be more efficient & powerful. Really though, if you're going over 30 MPH or so, the wind is doing most of the work anyways. For standard driving, a medium-sized single electric fan would be fine. Move up to a large single fan or the double for heavy hauling, long idling, & slow travel like off-roading. If possible, always retain the stock fan shroud. It directs air well, even after the manual fan is gone.
Old Aug 4, 2004 | 09:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
You could always try to find an electric that is the same size as the OEM fan shroud and mount it in the opening!
Old Aug 5, 2004 | 01:02 PM
fordborn's Avatar
fordborn
The single fan could probably do the cooling just fine but in the dual fan #270 as you mentioned this is a custom direct fit fan assembly. I actually have this kit and it fit like a glove and was able to install it in unde 30 minutes and wire it in another 30. A universal would have taken longer not to mention that it would not look as good.
Old Aug 5, 2004 | 05:57 PM
  #28
nemesis500548
How well would a single fan the same size as stock work? I live in San Antonio, so at least a half hour per trip is spend in medium to heavy traffic. I've never seen the needle on the guage inside the dash rise past halfway, even in heavy traffic for extended periods.
4 rings
Oct 18, 2013 11:53 AM
RUBICON
2009 - 2014 F150
38
Nov 23, 2009 08:47 AM
dhag911
18
Jan 2, 2008 09:27 PM
The Phenom
1997 - 2003 F150
Nov 30, 2003 07:59 PM
georgemu
Aerostar
Mar 12, 2001 11:58 AM
