Rebuild or Go UP!
Old Apr 2, 2004 | 03:31 PM
troysbowman's Avatar
troysbowman
Unhappy Rebuild or Go UP!
I am interested in either buying a crate 302 or going up to a 351.
Does anyone know of a good place to buy a crate motor? If I change to a 351 can I use my AOD transmission?
These may seem like funny questions to some, but just wondering what is involved.
Thanks for the help
Old Apr 2, 2004 | 10:28 PM
jmalecek's Avatar
jmalecek
The 351 will bolt up fine to your aod, provided that it's a windsor block. If you are going from a 302 - 351 you will need to change exhaust, (351 taller and wider), radiator hoses, possibly the water outlet on the manifold, motor mounts will be the same, distributor, acc brackets, P/S, Alt, etc... When I did my swap, I used the 302 alt bracket, it's a little tight around the bypass hose, but it doesn't kink it. I also used that big *** plate that mounts the p/s, and a/c. The upper pivot bolt will not line up on a 351, the bolt lines up with the freeze plug. I bought a pivot bracket from jamesduff.com ($26 including shipping) to fix this. If you want to go the crate motor route, look at jegs.com or summitracing.com, they will be cheaper than your local dealership, or autozone.
Good Luck
Jamie
Old Apr 5, 2004 | 07:00 PM
ga302p's Avatar
ga302p
If you know someone who races Fords, dirt track or drag strip, they can usually get you some killer prices from Ford Racing on crate engines. Most of your local guys who race Ford, have a pretty good hook up with an SVO dealer. I get parts from a dirt track racer who sells them to me at SVO dealer cost.
Old Apr 5, 2004 | 08:28 PM
fordbeast_80's Avatar
fordbeast_80
Depends how much you want to spend, Ford sells a nice 250 horse 351 for about $2500 set up with a flywheel for a man tranny.
Old Apr 6, 2004 | 06:57 AM
ALSAIR's Avatar
ALSAIR
Just be careful and read the fine print. The crate motors that summit sell's like the 302, say in fine print- NOT FOR SPEED DENSITY SYSTEMS OR E4OD TRANSMISSION'S. Just a little something to keep in the back of your head while shopping.
Al
Old Apr 6, 2004 | 12:07 PM
Kemicalburns's Avatar
Kemicalburns
I had a 302 in my 88 bronco and swaped a 351w in last summer. I found a wrecking yard 351w will low miles on it so I would get everything i needed. you will need a flexplate from a early 80's crown victoria that had the 351/aod combo. if you start with a long block, you will need the following 351w distributor, upper & lower intake, oilpan. you can use the accessory brackets off of a 302 just fine i did and everything lined up perfect. you can use the 302 wire harness
late
