Bronco II Ford Bronco II
engine clicking
Old Apr 2, 2004 | 10:49 AM
jakes29's Avatar
jakes29
engine clicking
87 2.9 4WD need some help. i know this could be a number of things but I have a clicking sound which sounds like it is coming from one of the spark plugs. any ideas?
Old Apr 2, 2004 | 11:29 AM
87 XLT's Avatar
87 XLT
Try running it in the dark and watch for sparks.
Old Apr 2, 2004 | 12:06 PM
hazzard64's Avatar
hazzard64
lifters
the ticking might be from the lifters, you reeally cant fix it that easy though. i have the same ticking in my 86 bii
Old Apr 2, 2004 | 01:09 PM
jakes29's Avatar
jakes29
what does it mean if I see sparks?
Old Apr 2, 2004 | 02:29 PM
Ken00's Avatar
Ken00
You may have bad plug wire(s) or the insulator on the plug(s) is cracked..
Old Apr 7, 2004 | 08:34 PM
85B2Owner's Avatar
85B2Owner
Also make sure the plugs are the right ones,wrong sizes can hit the pistons if they are too long.
Old Apr 7, 2004 | 10:30 PM
turborich's Avatar
turborich
turn off the lights and look for a spark jumping from the wires to any metal on the truck. valve covers, engine lift brackets, etc. make sure your plugs are tight. if its your lifters than you will have to pull your heads to get to them. try some marvel mystery oil. sometimes it helps. also how is your oil pressure??
Old Apr 8, 2004 | 02:35 PM
jakes29's Avatar
jakes29
oil pressure is normal. i will check for sparks tonight and let eveybody know what I find tomorrow. thanks everybody. ps.whats marvel mystery oil?
Old Apr 8, 2004 | 06:11 PM
wolffpax's Avatar
wolffpax
Like turborich stated, make sure all the plugs are tight.
