leaky transfer case
Old Apr 2, 2004 | 10:38 AM
norcalcapri's Avatar
norcalcapri
leaky transfer case
doing my ujoints today and noticed that the back of my transfer case has a little bit more oil on it than i would like, are there any seals or anything that are easy to replace back there that I could nail while i have the scrape guard off? or is it all hell no matter what? thank you very much again for all your help on my previous problems, you guys are awesome!
-tony
Old Apr 2, 2004 | 02:44 PM
Opera House Works's Avatar
Opera House Works
The rear seal can be replaced without too much problem. Unbolt the driveshaft from the flange. Later versions have a nut that you remove, earlier ones a clip. Under the nut, an O ring to seals the shaft. A jaw puller then pulls the flange out. Although, it doesn't take that mich force. The seal will pop out with a screwdriver. Polish the flange surface. NAPA does carry the rear seal, about $9. Some later versions, 4405, have a problem with the rear bearing mount. See if the rear flange has up/down movement to determine case damage.
