Glow plug relay?
Old Apr 2, 2004 | 07:26 AM
rms44's Avatar
rms44
Glow plug relay?
I have '99 SD 250 with 152K miles. Seems like the batery is draining down over the past 2 days. I'm not a electrical wizard so not sure what to check.
Thanks for the help!
Old Apr 2, 2004 | 09:35 AM
78fordman's Avatar
78fordman
Well, if you have original batteries, they are due for replacement. I replace mine every 2 years. I doubt the relay would be draining your battery. Take the ground off both batteries and put one on, see if it sparks. If there is a spark, make sure your dome light is not staying on.
Old Apr 2, 2004 | 09:37 AM
rms44's Avatar
rms44
Replaced both batteries. That's what i thought it was to begin with. I did not see a spark when I hooked up the battery last night.
