Sponsored by: Real Truck
19.5" Conversion rims
Old Apr 2, 2004 | 06:27 AM
Hotshoe's Avatar
Hotshoe
Anyone running Rickson's rims? I have been thinking about trying a set of
G&Y 124 245-70-19.5" H-load on my 02 F-250 Rcab 4x4.
Old Apr 2, 2004 | 08:35 AM
mjwhip2's Avatar
mjwhip2
A couple problems I see. Only rated to 75mph. I'm a little heavy footed so before I know it the needle is pegged. designed to be a drive wheel, not a steering wheel. Don't know if that is a problem on a light truck. Oh yeah, light truck, do you really need an H-load tire capable of 4800lb ea. on a 3/4 ton truck?
Hey, but whatever floats your boat. I like the Rickson eliminators.
Mike
Old Apr 2, 2004 | 02:09 PM
Autobahn F-250 Lariat's Avatar
Outpost22 runs 19.5 ricksons.
I'm sure he'll be around shortly to give you some good scoop.
Below is a pic of his SD with the rickson's
Manny
Old Apr 2, 2004 | 02:56 PM
Hotshoe's Avatar
Hotshoe
75 MPH limit? That's a problem. I would like to get them because of hauling G/N trailers with big pin weight all the time.
I like what i see in that pic.I wonder what size he is running?
Old Apr 2, 2004 | 02:59 PM
mjwhip2's Avatar
mjwhip2
The limit was from goodyears website. But you know they are always conservative on their estimates. Probably figured at max load anyway. Wasn't sure how they would look until I saw that picture. Not too shabby. I wonder how they would look on an older body style?
Mike
Old Apr 2, 2004 | 10:29 PM
Outpost22's Avatar
Outpost22
Originally Posted by mjwhip2
A couple problems I see. Only rated to 75mph. Mike
My 12 plies are rated for 85 mph. That "85" is figured for fully loaded at maximum temperatures. (fully loaded with these would put 8300 lbs on the rear axle...NO WAY would I do that anyway). So, speed isn't much of a problem, as an empty truck would have an increase in speed capability. You shouldn't drive that fast anyway I would not get the 14 plies as your axle would never tolerate the load you could put on those tires.
I can't tell any "ride" quality difference between stock 16's and the 19.5's when they are aired down to 75 psi. You can't beat these suckers for hauling a camper, or towing a heavy trailer. They will alter your rear axle ratio as they are slightly taller.
Old Apr 3, 2004 | 01:20 AM
bcs's Avatar
bcs
Talking love those 19.5s
I love the 19.5s I have
The ride is about the same, but you do notice the extra weight of the tires. Stock tire and Al. wheel were 62lbs and the 19.5 115lbs. The diameter is right on so the speedo is now exactly correct.
I have the Toyo M608z (14 ply rated) 5 steel plies in the tread and 1 in the side wall. Sure makes it feel more solid around the corners with that steel ply and the 70 series.
Can't wait to try the camper with these. I just got them in Feb.
Old Apr 3, 2004 | 02:23 PM
Hotshoe's Avatar
Hotshoe
Very nice.I'm thinking of PC steel wheels but have them coated in Shadow Grey (match truck color)and put my chrome center back like you did.
Old Apr 3, 2004 | 07:35 PM
Outpost22's Avatar
Outpost22
They really shine with the camper on. Thats where you'll really notice a difference.
Cross winds?...WHAT cross winds
FordsOnlyGarage
Jun 15, 2017 07:05 PM
Fert
6.7L Power Stroke Diesel
17
Aug 23, 2016 06:46 AM
baerpath
Jul 7, 2016 06:00 AM
mrcman58
Ford Truck Parts for Sale
Dec 31, 2015 08:43 PM
speakerfritz
Dec 17, 2015 05:22 PM
