No 2nd in C6
Old Apr 1, 2004 | 11:19 PM
twuck's Avatar
twuck
No 2nd in C6
What are the posibilities before replacement?
Old Apr 1, 2004 | 11:33 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Apr 2, 2004 | 03:57 AM
gregaust's Avatar
gregaust
You have a problem with the front band or servo.Start with a basic band adjustment.
Old Apr 2, 2004 | 08:46 AM
twuck's Avatar
twuck
Thank you - the tranny shop told me that it couldn't be that simple ... the guy didn't even offer to look at it first ... go figure ... they sell transmissions.
Old Apr 6, 2004 | 12:10 AM
The Tree's Avatar
The Tree
Well it may not be quite as simple. Drop the pan, filter, and valve body so you can look up in there. Next see if the is any play in the band. If so that may be the problem, also check for wear in the band that could be another problem. If the band is loose but the pad is still good then simply tighten the band. If both are bad you need to drop the tranny and get a new band. Or it could be the servo or valve body sticking.
Old Apr 6, 2004 | 02:00 AM
gregaust's Avatar
gregaust
If the band is bad there used to be what's called a 'snap in ' band that could be slipped in place without removing the transmission.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
