5 Inch Exhaust
Old Apr 1, 2004 | 04:05 PM
PSDJOE's Avatar
PSDJOE
5 Inch Exhaust
Seen A Lot Of Guys Talking About 5 Inch Exhausts But Where Do You
Find One That Big??? Also 4 Inch Downpipes??
My 96 Psd Dosen't Look Like The 3 Inch Dp Will Even Fit.
Joe
Old Apr 1, 2004 | 04:17 PM
CLK's Avatar
CLK
You can get a 3" down pipe on your truck it is tight if you go any bigger it will require bending the fire wall. I haven't seen anything bigger though. You'll just have to adapt it up to 5". It sounds sweet. We just did one for a guy the otherday on a 97 and it wasnt to hard.
Old Apr 1, 2004 | 04:20 PM
PSDJOE's Avatar
PSDJOE
But Where Did The 5 Inch Exhaust Come From?
Old Apr 1, 2004 | 04:23 PM
CLK's Avatar
CLK
I bought it from my local wholesale supplier, you can find them on the internet. E-mail me and I will send you a list of places ckersey2@***.net
Old Apr 1, 2004 | 10:35 PM
96ford4x4turbodiesel's Avatar
i got 5 inch side pipes on my 96 i was going to go 5 inch from the turbo but that was going to be a tight fit the only reason i could do that is because i got a 3 inch body lift
Old Apr 1, 2004 | 11:32 PM
johnsdiesel's Avatar
johnsdiesel
A 5" exhaust will not help performance unless you are putting out 450+ HP. If you want the look why don't you change from 4" to 5" near the rear of the truck and have a 5" exhaust to the tip?
Old Apr 2, 2004 | 04:45 AM
Quadzilla's Avatar
Quadzilla
That's absolutely true, but it will change the sound. When I went to a 5" system, the pitch got lower than it did with the 4".
I've got a Hypermax downpipe which expands to 3.5" after it clears the firewall, a stock 3.5" straight through muffler attached to that, then the "reducers" that expand the system from 3.5" to 5". There's a 48" long section of 5" pipe that connects the reducers to a 5" over-the-axle tailpipe, and then a 6" tip.
To me, it's the best sounding Powerstroke exhaust I've ever heard. At idle, it sounds pretty stock, except the pitch is lower. When I get into the throttle, the sound is nice and deep, though it never gets so loud that it's annoying. Anyone can tell she ain't stock at that point.
Just my $.02.
Old Apr 2, 2004 | 11:37 AM
96P_Stroke4x4's Avatar
96P_Stroke4x4
Smokin'
3" dp will fit with a little bending, 4" dp needs a lot more work... easy way would be to get a 3" dp that flares out to 3.5" after the firewall, and adapt to a 5" pipe that you can pick up at any big rig supply place. that's how i did mine, except with a 4" dp and 6" pipe exiting in front of the rear wheel in my '96... it sounds sweet... if conditions are right, i can hear a whine from the turbo at idle , a little on the pedal and it's all turbo
Old Apr 4, 2004 | 12:47 AM
Distinctive Dave's Avatar
Distinctive Dave
Just my $.02.
I agree, it will totally change the sound, 5 inch sounds deeper, I get nothing my compliments on my 5 inch with no muffler, hypermax exhaust. It sounds good and looks good with the chrome tip.
Old Apr 4, 2004 | 12:58 AM
WeWeld's Avatar
WeWeld
I like my 5" hypermax exhaust with my custom dual 6" stainless tips
see http://www.socaps.com/photopost/show...cat/500/page/1
GENE
Old Apr 4, 2004 | 01:07 AM
Distinctive Dave
Those tips do look pretty sharp, I like the pic of the duramax pulling the red Ford diesel, make the little guy do all the hard work. We know that the Ford could handle pulling that cheby around
Old Apr 4, 2004 | 01:38 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Forgive me for briefly going off topic, but what happened to that red 'stroker? It almost looks as if it's seen a fire.
Old Apr 4, 2004 | 02:29 PM
WeWeld's Avatar
WeWeld
The little red one???with the silver bed
GENE
Old Apr 4, 2004 | 05:52 PM
Toreador_Diesel
Yeah, it looks as if its taken quite a beating.
Last edited by Toreador_Diesel; Apr 4, 2004 at 05:54 PM. Reason: I'm now an Elder user :D
Old Apr 4, 2004 | 08:58 PM
WeWeld's Avatar
WeWeld
That is a 04 with 9.1 miles on it .
The truck started life as a reg cab long bed after I cut 16" out of the frame it is now a reg cab short bed. The bed came out of the junk yard but the truck is in the paint shop right now getting the bed red.
Here is a link to some more of the pics:
http://www.socaps.com/photopost/show...1013/password/
GENE
