Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Towing with the Escape
Old Apr 1, 2004 | 09:15 AM
rclloyd's Avatar
rclloyd
I am thinking of buying an Escape. I drove one and I am really impressed with it. The only concern I have is it’s towing capacity. We have a vacation house on a lake and need to launch and take out a boat twice a year. Do you think the Escape could handle a 20’ boat on the boat ramp. It weighs about 3200lbs. I am concerned it couldn’t pull our boat up the incline. We only need to trailer the boat about 1 mile to the house so I don’t think that would be problem. Thanks in advance…
Old Apr 1, 2004 | 11:00 AM
DoctorCAD's Avatar
DoctorCAD
Ya, it will do fine for that. I wouldn't tow that size boat very far or very fast, but for what you need, it'll work. Give yourself lots of braking room!
Old Apr 1, 2004 | 01:15 PM
Blackie60's Avatar
Blackie60
RCLLOYD, Are you going to buy 4X4 or just front wheel drive? Also what is the weight of tongue of your trailer?
Old Apr 1, 2004 | 02:17 PM
rclloyd's Avatar
rclloyd
I will buy a 4x4. Tounge weight is about 400lbs.
Old Apr 1, 2004 | 02:37 PM
DoctorCAD's Avatar
DoctorCAD
Shouldn't the tongue weight be 8 - 10% of trailered weight? That would put it at around 300 lbs.
Good thing you aren't going far, swaying would happen!
Old Apr 1, 2004 | 02:40 PM
Blackie60's Avatar
Blackie60
I think it will be little risky since 400lbs is little heavy since the rule of thumb is use 10 percent of gross trailer weight so, with 4x4 and that will help if you use it as short trip and the ramp is not long and too steep grade. Good luck!
Old Apr 1, 2004 | 04:51 PM
rclloyd's Avatar
rclloyd
You guys are probably right. I was guessing at the tongue weight. The trailer is made for the boat so I would suspect it's more like 300lbs.
Old Apr 1, 2004 | 04:58 PM
1956MarkII's Avatar
1956MarkII
One mile, twice a year? Take it slow, but do what you want. The max rated tow capacity is 3500 lbs, which I've always felt is optomistic, so you shouldn't have any problems.
Old Apr 2, 2004 | 07:49 PM
tsdrallyer's Avatar
tsdrallyer
I can tell you from many years of ramp experience, that power and rated capacity isn't everything. The ramp is almost always wet, so will need to have really good grip on the pavement. The stock tires are only so-so in ordinary conditions. Get some new rubber on that new Escape that is premium quality for wet pavement. Check out www.tirerack.com ratings.
I once towed a 3200lb sailboat for four years with a 3200 lb two wheel drive sedan (rwd) with no problems except one time. I backed down a little too fast and when I hit the brakes on the slime covered ramp, the car slid backwards toward the lake about three feet wiht all four wheels locked! When the boat floated, it reduced the weight enough that the sliding stopped! I never had trouble pulling out because of premium rain tires (the old Pirelli P77s) on the ground.
Old Apr 5, 2004 | 09:52 AM
gas_turbine_boy's Avatar
gas_turbine_boy
I've had no problems pulling my 3,000 boat with my '04 XLT escape. I'd advise getting the 4x4, it is most impressive.
2010escape
Jun 20, 2014 01:22 PM
northernsnooker
2011 - 2019 Explorer
Apr 12, 2013 09:43 PM
dugger54
Mar 20, 2008 07:14 PM
johny417
Apr 11, 2005 12:26 PM
ninx2
Feb 20, 2004 01:56 PM
