Sponsored by: Real Truck
F250HD Front End
Old Aug 9, 1999 | 06:49 PM
PaulB's Avatar
PaulB
F250HD Front End
When looking at the front of the truck, the top of the tires are tilted inward, the tired do not seem to be wearing, why is this?
Old Aug 9, 1999 | 09:09 PM
Jeff's Avatar
Jeff
F250HD Front End
It's an optical illusion. Because of the way the fenders curve around, it makes the tires "look" like they are closer at the top than at the bottom. I have the same thing with my old Dodge 4x4. If it really, really bothers you have a front end place check the alignment. They should do it for free. But if it costs a few bucks its worth the piece of mind!
Old Aug 10, 1999 | 06:54 PM
Fred's Avatar
Fred
F250HD Front End
Is your truck an older bodystyle 250?
Is it 4WD?
If so, there is a front end sagging problem to them.
If it's 2WD, then some tilt in at the top (negative camber) is normal, about .5 to 1 degree.
Normally on Fords, they are set this way to keep the tire wear more even, if there is any positive camber (tilt out at top) the outer edges will shave off really fast.
Twin I beam front ends travel up and down in an arc, which if you ride next to one, you can really see this, plus the wild camber changes as it moves through it's range of motion.
Old Aug 10, 1999 | 07:44 PM
PaulB's Avatar
PaulB
F250HD Front End
It is an older body style 4x4, If these trucks do have a sagging problem, what is the fix? and is it going to eat tires?
Old Aug 11, 1999 | 02:20 PM
Greg Lackey
Guest
Posts: n/a
F250HD Front End
