I've finished insulating my garage. Drywall is next. I found a few calculators on the web that estimate that I need about 18 4X8 sheets. Can anyone out there in the building industry confirm that I'm not going to be making 2 trips to home depot, the second either to return extra or to buy more? The walls are 9 feet high, and there is 75 feet of wall that needs to be covered. There are 2 7X9 garage doors and no windows. Any help is greatly appreciated. Thanks in advance.
Id Definately Go With 12 Foot Sheets If You Can They Cost Less Per Sq Ft And Cover More Wall Faster, Im Gussing Youll Need About 14 4x12 Sheets But You Need To Add A Little For Waste, Yes You Will Have Some Nad As Long As You Dont Damage Them You Can Always Return The Extras
If you calculated the square feet of coverage, divided that number by 32, that would give you the number of sheets needed, add one more for waste and/or mistakes.
Another thing to add,food for thought.Run a 1x6 treated baseboard around the perimeter first,then drywall from there up.that way you drywall does not get water damaged and if one of your boards does rot out,you simply yank it off and replace it.It is alot easier that repairing water damaged drywall.
Good idear! Thanks, I think I'll do this....At least around the part of the garage that is getting new sheet rock. The garage is attached, so the builider already did some of it... THanks again for the advice...
No, I'm not doing the ceiling yet. And as far as the dimensions, I'm finishing what the builder didn't. They only put up drywall on the sections that attached the house. I'm just finishing the open stud bays. Thanks for all the input guys! I appreciate it.
Almost all building centers will help you figure it, also it's a great idea to use the bigger sheets so that there is less seams vertically, therefore saving you alot of time and potential cracks. I don't know how much experince you have with it, but fill your seams with as little as possible-- will save you sanding in the long run. ALot of people cake it on -which means you will be sanding like a mad man . good luck..
why would you use drywall in a shop where you will be spilling oil and fluids and knocking holes thru it with jack handles? use plywood or osb..it's tougher
Have you looked recently at the price of OSB and drywall?
sure I have and ain't it a shame?..I am a union carpenter and also a residential contractor and found out why I've had to nearly double my recent bids..It's Iraq..the government is buying all the osb and plywood as well as much of the deminsional lumber and paying top dollar for it..they don't care cause it ain't their money but that makes it exceedingly tempting for the yards to keep their usual stock on hand so you pay much more..it's a shame...but I'd still prefer it to drywall as a lasting wallcover for a working garage
I saw government jobs using the most beautiful lumber I had ever seen for concrete forms. It was clear white pine, no knots at all... At the time I couldn't even buy lumber like that.
In an ideal world, I probably would too, but I'm on a budget. When (if) the price ever drops back to reasonableness, I may run a border around the bottom of the walls of OSB. Right now, I just don't have the cash to spend $17 per sheet of OSB.
