Head and dash lights flicker???
Old Mar 31, 2004 | 07:32 PM
Daytona guy's Avatar
Daytona guy
Question Head and dash lights flicker???
Does anyone know what would make my headlights and dash board lights flicker? On top of that, my idiot light for the alt. blinks at me at a regular pace, about three blinks per second. Then when I turn the clearance lights on, the idiot light slows it's blinking and when I turn the headlights on, the idiot light quits blinking. All of this just started last night.
I've had the charging system checked and it passes with flying colors. I went ahead and put new star washers at the engine ground cable and on the BAT side of the solenoid and the battery terminals are cleaned. and it still flickers...
Have any of you guys ever run across this and what did you have to do to stop the insane flickering???
The truck in question is a 78 F150 custom 2-wheel drive with a 351M mated to a C-6 transmission. That's better than
Old Mar 31, 2004 | 08:09 PM
Mil1ion's Avatar
Mil1ion
Bad ground wire on the connector that goes to the Ins.cluster.
The headlight switch could also need replacing, they don't last forever
Old Mar 31, 2004 | 08:36 PM
Daytona guy
Thanks Mil1ion...have you had this happen to you?
When you said "Ins. cluster" did you mean the printed film circuitboard behind the speedometer??? I guess it's time to have a look see, there's a couple of lights that need replacing. How can I identify the ground on this anyway??? Thanks for your help...
Old Mar 31, 2004 | 09:58 PM
Daytona guy
I think I need to amplify on what I meant when I used the word "flicker"...
The headlights and dash lights (really, all of the lights) don't turn off and then turn on, what they are doing is sort of a pulsing, brighter then dimmer then brighter then dimmer and this happens in a constant, continuous cycling, about 5 cycles per second.
Whew, I'm glad I cleared that up...
Old Mar 31, 2004 | 10:18 PM
Mil1ion's Avatar
Mil1ion
I very rarely suggest replacing parts but,
You can start by replacing the headlight switch.
Get a Quality part from say = Standard or Wilson.
The circuit breaker is located inside the switch.
The get old and cause the lights to flicker.
Better yet is to convert the ford headlight system into thr GM system of relays & be done with flickering lights
http://faq.auto.light.tripod.com/headlamp-harness.html
In response to the connection to the cluster the ground wire is black.
I don't know what position it is.
Old Apr 4, 2004 | 11:25 AM
Daytona guy
Mil1ion, I appreciate the suggestions you have offered and am sorry I haven't responded right away, I had to go out of town for a few days. Thanks again...
Old Apr 4, 2004 | 11:45 AM
HomerWinzlow's Avatar
HomerWinzlow
Could be a charging system problem too.
Old Apr 4, 2004 | 08:21 PM
Franklin2's Avatar
Franklin2
In the post "....whiter whites", his flickering lights turned out to be a bad diode in the alternator.
Old Apr 10, 2004 | 03:14 PM
Daytona guy
Red face
Well guys, the problem seems to have fixed itself, none of the pulsing and Alt. light is staying off except before starting...I suspect corrosion somewhere...
Old Jun 23, 2004 | 01:00 AM
bettendorf's Avatar
bettendorf
Question Pulsating Lights
I have a 1994 E-350 Shuttle Bus. 7.3liter diesel - non-turbo. 200 amp alternator. At idle the voltmeter reads a steady 13v or so. Driving down the road with no electrical loads the voltmeter will pulse between 12v and 14v. If I turn on the A/C the pulsating stops and the voltmeter will read 12v. If I have my headlights on they will pulsate along with all the other light on the bus. I just replaced the voltage regulator because the autozone guy recommended it. All they had was a 100 amp one - is that okay with a 200 amp alternator? It did the pulsating thing before I changed out the voltage regulator also.
Also, The A/C in this bus draws alot of power. If I have it on while idling the voltmeter will start reading 10v after about 5 minutes. Both batteries are brand new. Would a deep cycle for the main battery help at all?
Thanks, Jeff
1994 E-350 Shuttle bus
7.3 liter diesel - non-turbo
Old Jun 23, 2004 | 01:02 PM
Franklin2's Avatar
Franklin2
I would check all the wiring behind the alternator going to the starter relay. If nothing is melted, then the only recommendation I have is change the alternator. There have been some weird problems on here with alternators that just can't be diagnosed with a machine. Sometimes they work ok till you rev them up at a high rpm, or they start getting warm, then they quit charging. It's hard to troubleshoot something like that.
Old Jun 23, 2004 | 05:48 PM
HomerWinzlow
A lot of those older shuttle buses had alternators that were aftermarket with thier own heavy duty regulator. These were not Ford alternators, but installed by the company who built the shuttle bus body, like Bluebird and others. They often are dual output alternators. Its best to get a matching regulator for thier alternators. They often have complex wiring arrangements for the cables too and thier own regulator wiring harness spliced into the main loom.
newfordy
1997 - 2003 F150
Nov 9, 2014 06:29 AM
JST2CRZY
Vehicles for Sale
Aug 28, 2014 04:44 PM
El_Jefe
1983 - 2012 Ranger & B-Series
Jun 24, 2009 01:57 PM
sharpshooter73
New Member Introductions
Mar 17, 2005 10:15 AM
