k&n filter
Old Mar 31, 2004 | 02:27 PM
kbobbyexpy02's Avatar
kbobbyexpy02
k&n filter
i have a 2000 expy..and i was wondering if i were to put the k&n filter intake in my truck...would it be worth it and would it increase my horsepower at least by10??
Old Mar 31, 2004 | 03:28 PM
buzzard's Avatar
buzzard
You'll never feel 10 HP in a 6000# truck. I've gone back and forth between paper and K&N and can't tell a difference. Many swear that the K&N lets harmful particles through that are ultimately digested inside the engine. Also the oil on the filter can gum-up the MAF sensor if too much is used.
Old Mar 31, 2004 | 04:51 PM
Sturge's Avatar
Sturge
I put one in my '98 and swear I felt a difference but I swear my cars run better after I wash them and change the oil too! Seriously, it does make a bit of difference and it sounds cool too. Only a dyno before/after would tell you if it gets you 10 HP...don't believe what K&N claims. As for the filter letting larger particles through, that is true but...if you change your oil/filter regularly and don't run in a dusty environment much I doubt it will cause any problems. Follow the directions for how to clean and oil it and you shouldn't have problems with gumming things up. I just put a custome intake with a K&N filter on my Intrepid R/T and it has made a BIG difference. I also upgraded the intake on my Harley (along with exhaust and chip) and it's a HUGE difference. As posted above, with a 6000lb truck it is harder to notice much improvement but it's there.
Old Mar 31, 2004 | 08:37 PM
buzzard's Avatar
buzzard
I agree with Sturge, after hand car washes, my truck runs smoother than before. There are less sqeaks and rattles too.
Rembember 10 HP on a dyno would equate to only around 6-8 at the rear wheels due to inherent inefficiencies in the drivetrain.
Old Mar 31, 2004 | 08:39 PM
gcone's Avatar
gcone
I had one on my "01 SCrew-it did sound nice! The downside, which is strange, is that the truck shifted from 1st into 2nd at low (1800) RPM on a hard acceration - I took it off and it shifted fine (immediatedly) - put it back on, same old problem.
I ended up leaving it on because I liked the sound. I honestly can not validate any power or milage change one way or another.
Old Sep 10, 2004 | 07:47 PM
canadajin's Avatar
canadajin
I put a K&N air filter in my VW Vanagon Westfalia because I needed to squeak every bit of HP out of the 2.1L I could. I noticed a solid 2MPG increase and a little more power, which to me was worth it. I'm not sure you'd notice much better performance with something like an Expy. I have a 5.4L and am going to stick with paper. Anyone notice any difference using K&N on the 4.8?
Spencer
97 5.4 EB
Old Sep 11, 2004 | 07:10 AM
Bob Ayers's Avatar
Bob Ayers
Here are some dyno results of a K&N on a 3.0L Ranger (not paid for by K&N), and as you can see there was no difference. IMHO, they are not worth the $$, and not worth the risk of damage from dirt injestion, or contaminating the MAF sensor....
http://www.jackphelps.com/ranger/dyno1.htm
Old Sep 11, 2004 | 09:48 AM
WillieWildcat's Avatar
WillieWildcat
K&N Intake
The restrictive stock air box vs. the free flowing intake does make a difference in the amount of air the throttle body has to work with. You will gain some power, but it shouldn't be the only engine mod you do.
The best thing is to chip your computer. Superchips Microtuner will help you achieve greater horsepower gains than just an intake. The tuner will let you change shift points and even let you adjust the speedo/odo if you put larger tires on. I have a '98 which can't take advantage of all of the features of the tuner, so I bought an actual flash module which stays on my computer.
There other mods like a less restrictive exhaust (cat-back system), Trans-go shift kit for your tranny, and some hotter spark plugs like iridiums.
Old Sep 11, 2004 | 10:01 AM
OnlyFords4Me's Avatar
OnlyFords4Me
I just put a "drop-in" K&N in my 2004 Expy. I can't say that I noticed any power increase. However, I can almost swear I get 1-2 MPG worse than with paper! Has anyone else experienced this? I am going to change back to paper on my next fillup and see if it really is worse with K&N. Just wondering if anyone out there has noticed worse gas mileage with the 5.4L w/K&N?
Old Sep 11, 2004 | 10:54 AM
Aztrainer's Avatar
Aztrainer
I have one in my f-150 and there is only a difference in the gas mileage that I get. I put one in the wife’s Expy and it got worse mileage and messed up the MAF sensor. Both are 5.4's There has been a lot of debate on if they work and if they are good. I am not sold, but it seems to work for one and I will not put it in the wife’s Expy. Go figure
Old Sep 11, 2004 | 01:58 PM
wldcat65's Avatar
wldcat65
When I put the one on my 97 Expo I noticed a 2-3 mpg increase. I check my mpg every time I fuel up so this is a average. I would ave done it sooner if I knew what a differance it was going to make.
Old Sep 12, 2004 | 08:28 AM
Super_Irish's Avatar
Super_Irish
I put a K + N on the wife's '03 5.4 Expy without telling her. The next day after she drove it I asked if she felt a difference with it and she said yes it seemed as if it had more power.
I averaged around 17 MPG on a recent trip and that was at a constant 80-90 mph.
Old Sep 12, 2004 | 09:35 AM
Matt03Expy's Avatar
Matt03Expy
K&Ns don't filter the air as well and you probably won't feel a difference in performance.
Winmagbar
57
Jan 28, 2016 07:15 PM
astamp78
16
Dec 22, 2006 10:37 AM
moose94
15
Dec 30, 2004 09:23 PM
superrangerman2002
Oil & Lubrication
20
Mar 20, 2003 11:02 AM
Monsta
Modular V10 (6.8l)
Mar 22, 2002 03:06 PM
