Son's transmission
Old Mar 31, 2004 | 01:40 PM
bedwards's Avatar
bedwards
Son's transmission
Forgive me but this info is second had since I can't get it to act up myself.
My son's 98 ranger 4cyl auto will act like it completely drops out of gear when coasting after a 10-15mile interstate drive. It will rev up and the truck speed will continue to drop off to a point and then it will catch and drive fine from then on. It has only done this a hand full of times and is extremely intermitant.
The fluid and filter was changed 6-8 months ago with 10000miles maybe on the new fluid.
Any ideas sure would help.
BE
Old Mar 31, 2004 | 03:17 PM
Vin 95's Avatar
Vin 95
Is it like shifting into neutrel,then when RPM's come down it catches into gear?my truck did this and it turned out to be the throttle possition sensor,on the throttle body.Have auto-zone pull the check engine codes for any pending ones.The check engine light doesnt have to be on for it to have a pending or intermediat code.I bet you get a code PO222 or PO223,these are most common,but there are others that can indicate a bad TPS.
Old Mar 31, 2004 | 09:28 PM
bedwards's Avatar
bedwards
I checked the fluid tonight hot and its a good bit over filled. I'm going to drain some and get it in the hash marks and pray for the best.
BE
Old Apr 1, 2004 | 07:55 AM
Vin 95's Avatar
Vin 95
I'd still check for codes,you see, the TPS tells the computor when to shift the transmission,if it doesnt get a signal it will shift when it gets proper vaccum.you get highest vaccum at idle.I really didnt understand this,but after replacing my TPS my truck hasnt missed a shift yet.Before it would act like it hit neutral when you tried to accelerate hard(like geting on the freeway).
Old Apr 1, 2004 | 08:22 AM
Vin 95's Avatar
Vin 95
Oh yeah,.. Auto-zone or Advance auto will read your codes for FREE.
Old Apr 1, 2004 | 10:47 PM
el conquistador's Avatar
el conquistador
FYI, Advance Auto doesn't pull codes at all for liability reasons.
Old Apr 2, 2004 | 07:28 AM
Vin 95's Avatar
Vin 95
Advance auto read my codes here in Arkansas,but they wouldn't clear them.
Old Apr 2, 2004 | 02:59 PM
el conquistador
Hmmm Must be an Iowa thing or they just started it.
ckutter
13
Mar 1, 2014 12:10 PM
DmanNC
Dec 28, 2013 11:51 AM
hendedo
1997 - 2003 F150
Jul 12, 2011 08:31 AM
INTESP
1997 - 2003 F150
Mar 14, 2009 07:12 PM
66stangfb
Nov 21, 2002 12:01 AM
