Yes. Also check for 5V between the orange wire and the black wire too with the key on. I think the TPS could be damaged, but I don't know for sure.
Did some work on the truck over the weekend.The info you guys gave really helped and I appreciate it. I replaced the TPS and that seemed to help alot still have a rough idle but not quite as bad. The check engine light went out on replacement of TPS. I pulled codes again and came up with a 32. I removed the EGR valve and checked operation worked it manually and it seem to work ok. I did a a voltage check and got about 5 volts going to valve.Resistance read about 3000 ohms and book said it should be about 5000 ohms. I dont thnk the valve is working properly..Thanks again
Thanks for all the info . Where is the throttle sensor i just replaced some type of idle sensor? It has two screws that bolt on I guess is the throttle body and has a plug that goes into it.
