Towing limits for 73-79 Ford.
Old Mar 31, 2004 | 12:32 AM
78 f250 lariat's Avatar
78 f250 lariat
Did Ford ever list any max tow capacity for these trucks? If so where will I find it?
Old Apr 1, 2004 | 01:51 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
It was listed in the owner's manual which you probably don't have, or you wouldn't be asking! If you are looking for the info on a specific model and not the whole series, then post back with more information and someone with a manual may be able to help:
wheelbase or cab/bed configuration
4x2 or 4x4
GVWR
engine
transmission
axle ratio
Old Apr 1, 2004 | 07:46 PM
78 f250 lariat
4x2 or 4x4
GVWR
engine
transmission
axle ratio
F250 4x4 8 ft box 400 auto. Thanks.
Old Apr 1, 2004 | 08:53 PM
Flash's Avatar
Flash
This is out of the 1974 owners manual. There was not a 400 engine in that year but I will list the info for the 390- it should be close. It shows that the standard axle for your truck was the 4.10. The max trailer weight for your rig is 7,000 lbs with the trailer towing package or camper special. Otherwise the max trailer weight is 5,000 lbs. I have several of the 1974's and just limit them to 5,000 regardless of engine, transmission, etc. They all handle it quite good but anymore and the tow quality suffers quickly. I would suggest a good set of brakes on the trailer and a good controller. I use the old Kelsey- Hayes and it has been great. Also, listed is the rating for a 5er, that is 5,000 lbs-period.
Maximum tongue weight is 15% of trailer weight. They also recommend using the 9.50X 16.5 wheels and tires. Hope this helps.
Old Apr 4, 2004 | 10:28 AM
79_250RangerLariat's Avatar
79_250RangerLariat
I take it by your sig that your looking for the specs on a 78. The 74 info is a starting point but more than likely they are figuring using manual 4 wheel drum brakes. Which axles are you running?
Old Apr 4, 2004 | 07:57 PM
78 f250 lariat
Not sure it is a four wheel drive truck. By the way do you have any idea where to find reproduction interior parts for this truck. Items specific to Lariat?
guitarpicr
Nov 10, 2013 08:36 AM
Bad 674x4
Mar 14, 2013 12:03 PM
Jake4809
6.7L Power Stroke Diesel
26
Mar 26, 2012 09:09 AM
IBeam
General Automotive Discussion
16
Feb 17, 2006 09:38 AM
ford390gashog
Oct 21, 2004 07:26 AM
