I am trying to troubleshoot a short, on and off I get a clicking sound in the fuel contol solenoid at the carb. I have tested it and I have power to it at
all times (when the key/car is off)
I have tracked it back to the EEC power relay. If I disconnect the relay the power is cut off. I know there is always power to the EEC computer and that feeds the EEC power relay. Does anyone know if this is normal ? I would think the relay should control power to the fuel control solenoid when the key is at start or run position.
I dont know if the EEC computer has a problem or the power relay is bad ?
When my EEC relay failed there was a broken wire on the inside. Sometimes the fuel pump would work & than it would stop. I would be driving and it would stop. Used an ohm meter to check it out. Mine would open and close the contacts if I tapped it.Tap on yours. See what happens. I would change it out if it has never been changed and has over 100 k miles.
