trailerman; I was starting to have some valvetrain noise on both of my mods,
I used the seafoam in the oil & in the gas tank & of course in the vacuume line
the oil poured out like it was crude oil not synthetic mobil one 5-30, I also
switched to a higher detergent oil with a better over all package for wear
soot control & most importantly burn off control [shell rotella t 5-40 synthetic]. Try some of these things & that will help in this area.
. TURBO TED
i'll try answering all question,i use 5/30 castrol oil,i know its lifters because i've had valve cover off several times,it makes the noise atfer driving maybe 30 miles but sometimes you don't have to drive that far,i'll try changing to a different oil,thanks for the suggestions
