fuel tank vacuum
Old Mar 30, 2004 | 03:52 PM
176ford's Avatar
176ford
fuel tank vacuum
On my 76 250 my gas tank is behind the seat and its capped off right after the door. everytime i go to put fuel in my tank as i release the cap it has created a vacuum against the cap. I was wondering if this is harming my fuel system. my fuel pump might be over working itself or might one day cause the tank to collapse. i was wonder what the best solution would be.
Old Mar 30, 2004 | 04:17 PM
onetonscs's Avatar
onetonscs
I don't know if this is the best solution, but I drilled a very small hole in the cap for the rear tank on my '78 F150. I thought it would extend the life of the tank and possibly the pump.
Old Mar 30, 2004 | 04:34 PM
mark a.'s Avatar
mark a.
Buy a new cap. The vent isn't working. I wouldn't drill a cap, if you were ever to roll it over gas will run right out of the tank.
Old Mar 30, 2004 | 04:38 PM
onetonscs's Avatar
onetonscs
Mine was a new cap.
Old Mar 30, 2004 | 11:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
Some caps are vented and some are not. Some of them are marked.
Old Mar 31, 2004 | 09:23 AM
beartracks's Avatar
beartracks
The tank should be vented one way or another. My 77 vented through the fuel vapor cannister I believe.
