2005 SD and Excursion Order Guides are Out
New mono-beam front axle w/ coil spring suspension on 4x4
New 3 valve 5.4L and 6.8L gas engines
TorqShift trans avail w/ gas engines
Larger Rotors and new Master cylinders on brakes
Engine Idle Control included w/ the 6.0L and 6.8L engines
Upgraded frame for greater Load capacity
Increased rear GAWRs, GVWRs, Payloads and GCWR
Engine Block Heater is optional on 6.0L except for AK, CO, IA, ME, MN, MT, ND, SD, WI, WY.
Trailer Brake Controller - optional
Upfitter switches(4) Located on IP
All new 18" wheels on SRW
All new 17" wheels on DRW
New Grille
New Dual Beam Headlamps
New Front Bumper
New Exterior Badging
New Lower Accent Two-tone Paint Option on XLT and Lariat
New Premium Bodyside & Lower Accent Two-tone Paint option on XLT
Arizona Beige Accent color now available with the XLT Two-tone Paint options
New Secondary glove box on auto trans.
New dash with New gauge cluster
TurboBoost gauge on 6.0L
New Radios
Colors Added:
Dark Stone Clearcoat Metallic (XL, XLT and Lariat)
Dark Copper Clearcoat Metallic (King Ranch Only)
Dark Green Satin Clearcoat Metallic (King Ranch Only)
Colors Deleted:
Estate Green
Chestnut Brown
Deletions:
Max Front GAWR Package
Lariat LE Package
Options Revised:
Power Moonroof now requires Advanced Security Group
Lariat Luxury Package
-Electronic Auto Temperature Control
-Electrochromic rearview mirror
-Bronze-faced instrumentation cluster w/unique gauge color
-Enhanced message centerw/ Trip computer
-redundant Steering wheel controls
-Woodgrain instrument panel insert
-Center console w/ Woodgrain applique
Excursion stays pretty much the same with the exception of 18" wheels now optional on Eddie Bauer and Limited.
Egg crate style grille changes to nostril style
Jeweled Headlights replace crystalline
I dunno about you i think its kinda uglier, at least on the inside
and this... http://www.automotivetrends.com/2005...50spyshots.htm
05 MY order bank opens same dates for the Excursions
I also found out the last build job dates for 04 model year trucks is 7/3/04 for the SD and 7/2/04 for the X, Thats going to be a fast retool to make all those changes ????
but those are the dates shown on ford fleet.
