Just a couple quick ?'s if you please. Did a search and wondered if anybody can verify whether the speed signal wire is located in the large plug on the ABS module near the drivers side fenderwell? And I do have 4-wheel ABS. I just got my Truspeed today but the truck is in the shop right now gettin new gears, lockers and covers so I can't check and see. And when I calibrate it I should only need to calibrate it for the larger tires and not the gear change right? Thanks for the help!
1999 F250's and F350's under 10,000 lbs GAWR only had rear ABS.
I hope you're comparing apples to APPLES. I don't know where you got your info from but it's order code 67B. Look it up! That's the way I ordered it and its on the invoice. Now for the questions in the thread.
On edit: somethings amiss. Words appear in the reply box but not in the post when submitted? No, their not bad words.
