how much can a psd handle
Old Mar 29, 2004 | 10:00 PM
halerazor's Avatar
halerazor
i drive a cummins, but my friend just bought an 01 psd f350 6speed and he wants to add more power to it. gauges, air filter,exhaust i know what to look for in those but im not sure about the chips.he wants as much power as he can get for his money. i found a chip called max-e-tork that will go up to 220,but will the psd handle this without other modifications.is this chip any good and ive also heard that the most the stock injectors will put out is 70hp no matter what you do.
Old Mar 29, 2004 | 10:15 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The only limit is in his connecting rods. If his engine was built after 10/16/00 then he has powdered metal rods, and will be pushing the envelope if he takes it past 400 rwhp. If it's earlier than that date his rods are forged, and can make as much power as he can afford.
Never heard of this max-e-torque chip. Gotta link to a website?
Stock injectors can make 330hp to the rear wheels easily, and with the right combination you can push close to 400. The 7.3 aftermarket is only gotten geared up for real in the last six or seven months, there are only a few guys above 600 RWHP on #2 only, but that is just the tip o the iceberg.
Old Mar 29, 2004 | 10:25 PM
halerazor's Avatar
halerazor
here is the link for that chip www.turbo-master.com i was just looking around on the web for the most power for his money and came across it. its alot higher than any of the others.wonder why????
Old Mar 29, 2004 | 10:38 PM
cookie88's Avatar
cookie88
FTE Emeritus
A lot of tip in fuel and a lot of timing. Good way to make a window in a block.
I'd be interested in knowing who is writing his programming, and how he can offer a chip that is 55 horsepower stronger than the next closest guy, and half the price. Seems to good to be true. I'll be sending them an e-mail tomorrow, see if they'll give up any background information.
Old Mar 29, 2004 | 10:45 PM
halerazor's Avatar
halerazor
make sure you post the onfo they give you im pretty curious myself.i dont want my friend buying it and blowing his engine to peices. if it is true you cant beat the hp for the $.
Old Mar 30, 2004 | 01:03 AM
Go Aweigh2452's Avatar
Go Aweigh2452
Wow, does look too good to be true... weird we have not heard of these before...
Old Mar 30, 2004 | 06:32 AM
red4x4's Avatar
red4x4
So, would you say that the 205 HP chip is not good for a 2001 with the powder metal rods? I also have an intake, exhaust, and Garrett BB turbo.
Old Mar 31, 2004 | 01:05 PM
TJC1989's Avatar
TJC1989
Hey Cookie,
I have never had to mess around with my cam sensor, but my neighbor said if you rotated the cam sensor a little to advance fuel injection timing it would really boost the power. Of course, he used to have a Dodge with Cummins 5.9, before he got his Ford PSD, so not real sure which his comment was referring to. Is it possible to make minute changes in the cam sensor positioning on the PSD to change the timing?
Old Apr 4, 2004 | 01:02 AM
Distinctive Dave's Avatar
Distinctive Dave
I dont think its possible to do the cam sensor turn thingie. The cam sensor is held in place by a bracket/screw. The other thing is that if you look at a CPS, it looks like a plug, with an eye that just looks....like its just seeing where the cam is. I have never heard of moving the cam sensor to make power. Maybe its a D*DGE thing, sorry guys i said a naughty word, (d*dge)
Old Apr 4, 2004 | 01:11 AM
cookie88's Avatar
cookie88
FTE Emeritus
Not neccessarily. The rule of thumb is that PM rods can hold around 400 RWHP before it starts getting dicey. Normally it takes at least stage II injectors with a big turbo to go past 400.
Anybody else want to send them an e-mail? I asked some pretty direct questions about how the power is made with that chip, but have not yet recieved a response.
Old Apr 4, 2004 | 08:45 AM
red4x4's Avatar
red4x4
Cookie, I spoke directly with the owner of that company, and he seemed pretty straight forward. But then again, since I'm no computer genius, I didn't know what questions to ask. You may try calling and asking directly. He seemed pretty cool, but then again he was trying to sell me something. Please post if you do!
I'm new to this. What is considered a "big turbo?" I have a Garrett GT38R BB Turbo, 4" exhaust, AFE intake, and a Hot Chip, If I decide to go with larger injectors, would I be screwing myself?
Old Apr 4, 2004 | 11:35 AM
cookie88's Avatar
cookie88
FTE Emeritus
The 38R is big enough for the job. If you go with big injectors you will be pushing the envelope with PM rods. Might end up with a brand new inspection hole in your block. Don't get me wrong, it is doable, you'll just have to back the timing way down on the chip, and maybe add something else (like water injection) to control the cylinder pressure.
I'll give him a call next week. I am very interested in knowing who is doing his programming.
Old Apr 4, 2004 | 02:06 PM
red4x4's Avatar
red4x4
Thanks Cookie. Don't need a big inspection hole!!! What's this water injection? Will it compromise performance? I don't mean to sound ignorant, But I am!! Diesels are all new to me.
Old Apr 4, 2004 | 04:10 PM
cookie88's Avatar
cookie88
FTE Emeritus
Quite the opposite. Water injection can add 50-90 hp while lowering cylinder pressures at the same time. I ordered a kit that should be here by moday, so hopefully I'll have some real world info by next weekend.
Old Apr 4, 2004 | 04:42 PM
red4x4's Avatar
red4x4
Very Cool!! (No pun intended)
What's something like that go for, and how hard of an install. Thanks again!!!
