coolant temp sender location
Old Mar 29, 2004 | 04:07 PM
Jack01's Avatar
Jack01
can some one tell me which send sends to the computer and which sender sends to the dash mounted factory gage. I have a 1995 F-150 supercab with 302/auto trans
Old Mar 29, 2004 | 04:20 PM
RLKBOB's Avatar
RLKBOB
They are both on the front of the intake manifold. The one over the water neck with the bigger plug is the one that goes to the computer, the one just to the right of the dist(looking at it from the front) with the single wire and connector that slides over the threaded post goes to the dash guage.
Old Mar 29, 2004 | 04:43 PM
Jack01's Avatar
Jack01
thank you RLKBOB for the info..
Old Mar 29, 2004 | 09:37 PM
yz250joe's Avatar
yz250joe
the dash gauge can be tested by grounding it and then checking to see if the gauge in your truck moves all the way to hot. If so the unit is good and the computer plug is malfunctioning.
