Sponsored by: Real Truck
ESOF
Old Nov 18, 1999 | 09:46 PM
gclackey's Avatar
gclackey
ESOF
Have many of you had problems with ESOF? Was at the coast and could not get 4WD to engage with ESOF. I hear the vacuum pump when I turn the ignition and my heat is working fine. Any ideas?
Old Nov 19, 1999 | 09:14 PM
snomoman's Avatar
snomoman
ESOF
On my 99, the vacuum line came loose from it's mount and touched the exhaust. Once melted, nothing worked. I've heard that there were other problems with the 99 hubs. You didn't state what year the truck is, but the dealer should be able to upgrade the hubs. All I can say is that the manual over-ride was the smartest thing they ever did.
Old Nov 20, 1999 | 07:04 PM
gclackey's Avatar
gclackey
ESOF
It is a '99. I did wind up using the manuals. I just hate paying the extra $$ for something that will not work. I'll check those vacuum lines. Thanks.
Old Nov 21, 1999 | 09:59 AM
J.C.'s Avatar
J.C.
ESOF
My hubs wouldn't lock in and I found out the connector on the solonoid valve wasn't pushed on all the way. The valve is located on the passenger side fender. If my memory serves me right, it has two vacuum lines and a connetor with two wires going to it. If you can't find it, just follow the vacuum lines from the hubs up to the tank and then to the valve.
Old Nov 21, 1999 | 10:09 AM
J.C.'s Avatar
J.C.
ESOF
Countryboy1973
Jan 7, 2017 06:56 PM
custom63willys
Sep 20, 2016 10:27 PM
hpcbmw
Sep 16, 2016 12:22 PM
FreeDevin
Sep 5, 2016 08:12 PM
bcaughhorn
19
Mar 22, 2015 02:05 PM
