Sponsored by: Real Truck
Door Panels
Old Nov 18, 1999 | 03:46 AM
sarhog's Avatar
sarhog
Door Panels
Old Nov 21, 1999 | 07:27 AM
edlow1's Avatar
edlow1
Door Panels
How do I remove the door panels on my 2000 SD CC? I dont see any screws, and I tried pulling hoping for push clips, but I didn't want to break anything. Is there a trick?
Old Nov 21, 1999 | 10:09 AM
J.C.'s Avatar
J.C.
Door Panels
I'm not sure how it is with trucks without power windows and locks but, trucks with them have two screws holding them on. One screw is behind the reflector and the other screw is under the power window/lock console. To get the console off, just lift up on the front of the thing till the front comes unclipped and slide forward. You'll also most likely will have to remove the trim piece on the door pillar and that just pulls off. Once you get the two screws out and the trim piece off, the whole door panel just lifts right off. Even if you're slow it shouldn't take more than two minutes. It' the niftiest door panel I've seen. Far better than all those stupid little clips that would always break.
bradphx
67
Jan 10, 2024 06:12 PM
