E350 Any c6?
Old Mar 29, 2004 | 10:44 AM
zippylaredo's Avatar
zippylaredo
E350 Any c6?
I need a new c6 for my E350 cube van and am wondering if any 2wd C6 will do? Are they all the same?
Old Mar 29, 2004 | 01:29 PM
Casey's Avatar
Casey
No, they are different with different engines.
Old Mar 29, 2004 | 01:57 PM
zippylaredo
Any idea what ones (if any) will work? My truck has the 351w, will one from a 302 or 300i6 work?
Old Mar 29, 2004 | 03:13 PM
Boss_358's Avatar
Boss_358
Yes, these engines all have the same transmission pattern. Now I have seen some 460 C6's with different tailshaft lengths. I don't know if they vary on small block versions. I have not really seen many small block C6's.
Old Mar 29, 2004 | 06:03 PM
zippylaredo
So, can I assume that all of C6's have the same gear ratio's?
Old Mar 29, 2004 | 09:24 PM
Ford79's Avatar
Ford79
Yes same gear ratios on all of them.
Small block C6's are hard to come by, but if you get a good transmission in a different style (either 385 big block of FE big block) you can swap all the internals over to your small block case. Or, you can rebuild it youself, they aren't too hard to do if you have a good manual and/or a video.
Old Apr 9, 2004 | 12:06 AM
zippylaredo
I'm lucky enough to have a few used one's to choose from. Are there differences in the tailshaft sections and, if so, can I interchange my old one? Thanks!
quaddriver
Aug 16, 2010 02:49 PM
fordinmudd
24
Sep 3, 2008 03:06 AM
packlet
All Things Towing
Nov 12, 2003 07:13 PM
regtqm95
Mar 18, 2002 01:45 PM
