Sponsored by: Real Truck
V10 hp?
Old Nov 26, 1999 | 02:12 PM
Bodyman
Guest
Posts: n/a
V10 hp?
99 F250SC 4x4 LB 3.73 auto
First of all love the truck and I'm convinced it's
the best.Now I'd like to discuss a couple of things. Where did ford come up 275 HP.From what I have seen it's 220 at the rear wheels.When did ford stop using SAE HP that was the base line
started in 1972 for rating auto HP?
Next I've been reading about your mpg and I only
get 9mpg in the city.Whats up with that? The truck
seems to run good and it's been like that since
day one 9/98 and has 8200mi. Also I work at a
multi dealer body shop and we sell GMC trucks[yuk]
Old Nov 26, 1999 | 02:38 PM
wawii's Avatar
wawii
V10 hp?
BodyMan,
The quoted HP by the manufactures is measured at the engine, and not at the rear wheels. Based on all the different Trans and diff. combinations, they only rate the engine so it's the same for all configurations.
The 275 HP Ford quotes for the 99 and 99.5's is measured there. You will likly see a 15-25% reduction in this at the rear wheels. My 2000, which was rated at 310 HP would measure around 245 HP is I could get past the speed limiter. You can see the my results at <a href="http://ic.net/~wawii/Dyno">http://ic.net/~wawii/Dyno</a>/
As far as fuel milage, I'm seeing better than you, but I'm not doing any true city driving with mine. I have noticed that accelerating does pull a lot of fuel, unless you do real slow acceleration. My fuel usage log is at <a href="http://ic.net/~wawii/MPG/00F250SD">http://ic.net/~wawii/MPG/00F250SD</a>/
My SD is a Y2K F-250 Crew Cab Short Bed 2WD Auto w/3.73LS.
Hope this helps,
Will
Old Nov 28, 1999 | 05:41 PM
Todd MacLean
Guest
Posts: n/a
V10 hp?
coletr2
Feb 6, 2017 07:28 PM
Resendiz
26
Aug 23, 2016 04:24 PM
RandomNewGuy
Nov 13, 2015 09:05 AM
sirrealism
17
May 14, 2015 09:57 PM
jdhudall
1997 - 2003 F150
Mar 27, 2012 03:40 PM
