Painless wiring help
Old Mar 29, 2004 | 08:56 AM
1968stepside's Avatar
1968stepside
Question Painless wiring help
I just finished installing my 18 circuit universal in my 68 F100. The directions say to use a battery charger with 10amps or less. The closest setting I have is only 2amps. I get power to the fuse block, but nothing out. Well, I did put my test light to the contacts on each fuse and had power. It was only momentary though. The charger has a deep cycle and regular automatic settings. I have had problems deciding the correct connections for the ignition switch. I found a replacement pigtail (new) for a 72 model. I have the correct switch. Problem is, the wires are all black on the pigtail. I had to trace wires on my buddies 72, but am still unsure.
Anyone have any experience with these?
Please help!
