squeaky exploder
Old Mar 28, 2004 | 10:24 PM
norcalcapri's Avatar
norcalcapri
squeaky exploder
ive got a 96 4wd with a 4.0 and its been squeaking really bad recently. it sounds like metal rubbing up against metal kinda, like a bike chain that needs to be oiled. it gets faster as i go faster, and its starting to get louder and louder. i just replaced the hub today but no dice, i dont know where to go next. any ideas on what else it could be? anything would help, thanks!
-tony
Old Mar 29, 2004 | 10:33 PM
c96drumm's Avatar
c96drumm
Does the noise change if you apply the brakes?
Old Mar 30, 2004 | 07:20 AM
98txexplorer's Avatar
98txexplorer
Does it sound more like a chain being dragged on the ground?
If so, you could have a bad timing chain tensioner. Recall on the 4.0L.
Old Mar 30, 2004 | 03:04 PM
norcalcapri
squeakiness worsening
nope, this sounds like something needs to be oiled. sounds like it might be coming from a little farther back than the wheel though. now theres a clunking noise too, nothing to loud, but it goes along with the squeaking. i wont hear it after starting from a stop unless i floor it or go above a certain speed. and when i brake it doesnt go away, but it does silence it just a bit, could this be a bad u-joint or something with the front diff or transfer case? never dealt with 4wd before so im clueless, thanks again for your replies.
-tony
Old Apr 2, 2004 | 10:43 AM
norcalcapri
found it
turns out it was the u-joint on the front drive shaft that were causing the squeaking, clicking, and extreme bumpiness above 61mph. yay, ive got the double cardan type line so ive gotta replace 3 u joints. but took it out for a test spin with the line off and it drove like new. thanks for the input!
-tony
