Headlights Help
Old Mar 26, 2004 | 07:26 AM
SCHETTLER's Avatar
SCHETTLER
Angry Headlights Help
I HAVE A 98 EXPLORER XLT. I dont have any low beams all other lights work. the brights work if you pull the lever but wont stay on. I tried all fuses and replaceing bulbs, with no luck. I looked for the lom in the center consoule and only found a wire block. any help will be great.
Old Mar 26, 2004 | 07:41 AM
nhfire 77's Avatar
nhfire 77
sounds like the headlamp switch on your dash is No good. Its a pain to change but i would consider it a possibility, plus if the illumination was already out it will be back with a new switch-small consolation
Old Mar 26, 2004 | 12:17 PM
SCHETTLER's Avatar
SCHETTLER
test
can you test the switch?
Old Mar 26, 2004 | 12:45 PM
87 XLT's Avatar
87 XLT
If I had a 98 Explorer, I would also have an "Electrical & vacuum troubleshooting manual" for it. Only 30 bucks at www.helminc.com My guess would be a bad multifunction switch which is very simple to test with an ohm meter. The manual will tell you how to test it. By making electrical repairs simple to do myself I figure this manual has saved me around 800 bucks so far. Not bad for a 30 buck investment.
Old Mar 26, 2004 | 11:32 PM
96explorereddieb's Avatar
96explorereddieb
Yeah, it can be your multifunction switch (turn signal stalk).
Old Mar 27, 2004 | 05:22 AM
stonem77's Avatar
stonem77
It good be a bad LOM (lamo out module) i have heard that this is the culprit on many vehiles as well as the multifunction switch. It is located near the centre console in behind you driver info centre.
I have read this in this forum so check or search for lamp out module and you may fine more help
Old Mar 27, 2004 | 05:41 AM
prcrboy's Avatar
prcrboy
Stonem is correct. As a matter of fact all of them are correct.
However, don't overlook the obvious. The bulbs. A freind once complained the saME. Turned out he lost one of the low beams a long time ago and didnt notice and then the other burned out. So check that first.
Then, there is the info. center. Do you have the info center in the lower console\? If so, the healight signal passes through those for the monitoring part of the console. If its this, the info center will tell you bad headlamps even with a new bulb. It senses the current.
Then theres the multiswitch. Get a good manual, a voltmeter and start checking voltages.
Old Mar 27, 2004 | 01:41 PM
96explorereddieb
XLT's don't have LOMs. Only Eddie Bauers and Limiteds have them because of the message center in the center console.
Like what I and 87 xlt said, it could be the multifunction switch.
Old Mar 27, 2004 | 05:44 PM
SCHETTLER's Avatar
SCHETTLER
thanks all how would you test that?
Old Mar 29, 2004 | 04:35 PM
SCHETTLER's Avatar
SCHETTLER
replaced the multifunction switch. Lights work great thanks for all the help.
Old Mar 29, 2004 | 05:14 PM
87 XLT's Avatar
87 XLT
Thanks for the update, glad to hear it's fixed.
Old Apr 1, 2004 | 06:01 PM
explorer95ltd's Avatar
explorer95ltd
Unhappy no low beams!!!
Hi there, I have a Explorer 95 limited. high beams works good, but not the low beams i changed bulbs, checked fuses everything, is ok but wasn't able to find the relay, please help thank you.
Old Apr 2, 2004 | 11:19 AM
87 XLT's Avatar
87 XLT
Are you sure this has a relay??? Take a look at a wiring diagram and if the only difference between high and low beams are the electrcal paths thru the multifunction switch then the switch is shot. If you want to be able to easily figure out this sort of thing, get the manual I mentioned.
