Head question
Old Mar 28, 2004 | 08:36 PM
WhëëlMå1's Avatar
WhëëlMå1
Head question
I have a 96 351. I remembered I had some issues with my headers (I actually ended up cutting the flange because I thought the plug was too close to it). What is the difference between stock 351 heads, and I think they are called Gt-40P heads? What angles (Approx). do the plugs come out on each? I think I might have different heads (I'm not the original owner). I believe the sticker on the drivers side head says it was made in 1997, a year after my truck. This is what my setup looks like:
Any ideas? Thanks
Rich
Old Mar 28, 2004 | 09:31 PM
Cloim's Avatar
Cloim
iirc, the plugs on the p heads exit at close to a 90 degree angle.
That looks like stock angle to me.
That does look like a tight fit. If your having problems, you might want to try a fiberglass boot sleave on the plug wires.
