wheel bearing replacement
Old Mar 28, 2004 | 08:57 AM
Tidybowlman0's Avatar
Tidybowlman0
I need to replace the rear wheel bearing on my 87 bronco. It has an 8.8" rear in it. are there any special tools required? What parts will I need to complete the job? Should I do both sides at the same time or just the one that is chirping(right side)?
Old Mar 28, 2004 | 09:52 AM
MustangGT221's Avatar
MustangGT221
Well if the bearing on the axle tube is worn out, chances are the whole diff's bearings are gone too. To replace the axle tube bearing you need to pop the diff cover off, pull the C-clips on the axle shafts, remove the axle shafts. Pull the seal out with a seal puller, then using a slide hammer with the right bearing puller attachment remove the bearing. With a bearing knocker tool or equivilant put the new bearing in until it sits flush and put a new seal in. Make sure the axle shafts don't have any pits or rough spots where the bearing rides, it needs to be smooth or they're not much good.
Freds04explorer
Mar 14, 2013 11:30 AM
mrman0901
20
Jun 12, 2007 07:09 PM
TexasGuy001
Feb 5, 2006 11:09 AM
Dustin_86
General Automotive Discussion
Dec 24, 2005 06:52 PM
Skips97
Jan 21, 2004 10:43 PM
