3.0L pinging and 180 degree thermostat
Old 03-27-2004, 10:15 PM
rxdawg's Avatar
rxdawg
rxdawg is offline
I am experiencing the infamous 3.0L pinging problem and am considering a 180 degree thermostat, but I dont know at what temperature the computer enters closed loop. I ask because there is a 185 thermostat made for GM products due to closed loop issues.
Things tried so far on 1996 3.0L/5 speed (80,000 miles):
DPFE sensor
Tuneup - Plugs and wires, Fuel and air filter, PCV
Cleaned MAF, throttle body
Chevron Techron injector cleaner
Checked air temp sensor, EGR valve
The DPFE sensor seemed to help a little. My coil pack is not affected by the TSB. Computer was reset afterward by removing battery cable.
Any other suggestions would be appreciated. Thanks.
Edit: Truck runs great on 93 octane. Havent tried 89 since changing the DPFE, still trying 87.
Old 03-28-2004, 02:20 AM
R6elmo's Avatar
R6elmo
R6elmo is offline
from reading various forums etc, 180F is about teh limit of where the comptuer enters closed loop. I'm currently using the 180F t-stat without any negative effects. The temp gauge is on teh low side though..about the lower 1/4 mark.
Regarding the pinging. I would normally say ignition advance, but i don't think we can adjust that with this system. You cuold also look into plugs and get one heat range cooler.
Old 03-28-2004, 08:21 PM
Ken00's Avatar
Ken00
Ken00 is offline
Ford can reprogram the PCM to help, they can also retard the timing if needed.
Old 03-28-2004, 09:17 PM
rangersvt04's Avatar
rangersvt04
rangersvt04 is offline
cooler sparkplugs and is that 5speed a stick or auto? ive got autolight plugs in my96 and she only pings when shes underload (climbing a curb....iknow its sad) and warm. i can climb the same curb if shes cool and no ping? ware can i get one of them 180 thermostats at?
Old 03-29-2004, 09:14 AM
rxdawg's Avatar
rxdawg
rxdawg is offline
Thanks for the help.
Where can I get some documentation on the PCM reprogram? Is it a TSB? What does it do other than remove some timing?
Its a 5 speed stick. I am using Autolite DP plugs, and my truck does the same thing as yours - runs great on 87 until it fully warms up, then pings under load.
Do you have an manufacturer/part number on a 180 thermostat?
Old 03-29-2004, 02:11 PM
Ken00's Avatar
Ken00
Ken00 is offline
I'm not sure what the programing does but would guess it modifies the timing curve. By reducing the timing advance you would lose a little power.
Old 04-02-2004, 03:31 PM
bassaway's Avatar
bassaway
bassaway is offline
I tried the 180 degree thermostat in my 2000 ranger 3.0 V-6 and replaced it with a new stock thermostat a week later. The 180 therm kept the truck in closed loop and i lost about 3 mpg. still searching for a solution to my pinging...i miss the days of hitting the gas and hearing nothing but power(well, 3.0 power at least).
Raise
03-27-2017 01:11 AM
shooter123
1997 - 2003 F150
16
12-06-2016 11:17 PM
SgtJoe
Aerostar
12-22-2004 01:01 PM
fordrangerman
3.0L V6
26
06-20-2004 06:14 AM
Quick Reply: 3.0L pinging and 180 degree thermostat
