Bfg 295/75/16
Old Mar 27, 2004 | 08:40 PM
Jerrod's Avatar
Jerrod
Bfg 295/75/16
What is the best pressure to run for even wear? Front? Rear? How often on rotations?
Old Mar 28, 2004 | 07:19 AM
79CEEJAY's Avatar
79CEEJAY
I run mine at 55psi, and rotate every other oil change. I pull often, but rarely load the bed with heavy weight. If you max out your gvw, you will want to run them at max psi as stamped into the tire. The 295/75/16 BFG is an 8 ply tire and the factory tires are 10 ply. So make sure you inflate according to your BFG's pressures, and not the OEM 10 ply's pressure rating. BTW, I usually rotate mine front to back without criscrossing. I have had good luck with this so far.
Aerostar
Aug 21, 2024 11:23 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
wolfmanagh
Jul 9, 2012 04:40 PM
Apr 13, 2004 12:08 AM
jamyboy
Jan 6, 2003 11:17 AM
