1978 - 1996 Big Bronco
Excessive play in steering wheel?
Old Mar 27, 2004 | 06:38 PM
genueix's Avatar
genueix
Hey all,
I noticed there seems to be a lot of play in my steering wheel...I can turn it approximately 1.5"-2" left and right before it feels like I have steering control over the Bronco. Is this normal, I can drive fine with it like this...I would just feel a little better if I knew I had that much more control over the Bronco.
Also, I find that the steering wheel has to be held to the left to drive straight...so it is not straight across. However, if I let go of the steering wheel the alignment seems to be fine compared to how much the steering wheel seems to be turned to the left.
Thanks!
-Nick
Old Mar 27, 2004 | 06:53 PM
boulderbronco's Avatar
boulderbronco
That movement of the wheel without a reaction is normal. Sounds like you could stand for an alignment though. TTB's are notorious for eating tires if not properly aligned.
Old Mar 27, 2004 | 11:57 PM
christop43's Avatar
christop43
I agree
My Bronco has had loose steering since I bought it. I am sure you could start replacing things, but that would cost a lot of money Rag joints, steering shafts, tie rod ends, and the list goes on and on.
Funny thing is I have never had a problem with tire wear on my Bronco.
Old Mar 28, 2004 | 04:16 AM
nordo's Avatar
nordo
Steering Slop
I just replaced my steering rod ends last week, I was amazed at how much better the thing drives!
If you can both front wheels of the ground, move the wheels to see if there is excessive freeplay in any of the joints. If there OK it may be slop in the steering box, which can be ajusted quite easily as long as its not fo far gone.
Andrew
Old Mar 28, 2004 | 05:17 PM
bronco5.8's Avatar
bronco5.8
I agree with nordo on the gear box adjustment, there's an adjuster on the top of the steering gear box. Now if you have to hold the wheel to the left to drive straight then you'll need an alignment. Be sure to check all your balljoints and tierod ends.
Warr
SoCalAngler
May 4, 2020 07:10 PM
bfediuk
Jul 20, 2019 10:00 PM
cajun_driller
6.7L Power Stroke Diesel
Mar 16, 2014 07:30 PM
meborder
May 12, 2012 03:02 PM
2FordTrucks
Dec 29, 2003 06:17 PM
