C6 rebuild...no forward...has reverse???
Ok so I rebuilt the tranny and now it doesnt move forward unless I rev it very high. It goes into reverse just fine. Any ideas or suggestions???
I would guess that there is a problem in the forward clutch hydraulics. (broken cast ring on the forward cylinder or a cut rubber seal on the forward clutch piston.
I remember finding one on the net somewhere - do a Google search and I'll bet you hit paydirt.
If you have to go back into the tranny, I suggest that you use the Haynes manual for Ford transmissions (includes the exploded view) plus spend an extra $28-$30 for a how-to tech video. That's the best 30 bucks I spent when I re-did my C6. Between the manual and the video it's very straightforward.
