Transmission swap
Old Aug 12, 2015 | 07:05 PM
cannonman's Avatar
cannonman
Transmission swap
Hey guys. I've got a 78 F100 swb 2wd 300 inline 6 with a C6 automatic troubles. The forward gears don't engage but it goes into reverse just fine. Checked the linkage and that's where it should be, thinking it's the torque converter. Planning on a rebuild. But I have found another C6 auto from a 91 with the 300 for a good price. It's a Heavy Duty C6. Wondering if it will be a rudimentary swap or will the HD pose an issue. Your thoughts?
Old Aug 12, 2015 | 07:13 PM
Jrgunn5150's Avatar
Jrgunn5150
You probably lost the apply piston for the forward clutch.
The newer trans should swap fine, AFAIK the differences are all internal.
Old Aug 13, 2015 | 08:30 PM
cannonman's Avatar
cannonman
Thanks for the info.
Old Aug 14, 2015 | 11:47 AM
cannonman's Avatar
cannonman
@ jrgunn5150. This apply piston for the forward clutch, is that an internal mechanism? This is my first time tackling the C6 transmission
Old Aug 14, 2015 | 02:43 PM
bkaul's Avatar
bkaul
Yes, it's internal to the transmission - the clutches and bands are hydraulically-driven; the piston that engages that clutch is sealed by essentially a large O-ring, and that seal has presumably failed, so that the hydraulic pressure no longer engages the clutch, but just slips past the piston.
Old Aug 14, 2015 | 04:07 PM
Jrgunn5150's Avatar
Jrgunn5150
^^Yep, unfortunately it basically means a rebuild.
Old Aug 22, 2015 | 08:25 AM
cannonman's Avatar
cannonman
Welp, the rebuild will be my Fall project. Thanks again for your help.
cannonman
Apr 21, 2015 08:07 PM
styner5
Jul 4, 2012 09:00 PM
nothercrash
30
Feb 17, 2012 05:48 PM
czechyour6
Oct 28, 2004 09:30 PM
Tim
Mar 2, 2000 11:34 PM
