Aerostar Ford Aerostar
quick question
Old Mar 26, 2004 | 07:37 AM
pollok's Avatar
pollok
Question quick question
how do u replace the light for the gear selector (P, R, D, 1, 2)? Also is there a easy way to remove the top dashboard to gain access to the speakers?
thanks
Old Mar 26, 2004 | 07:38 AM
tom_foreman's Avatar
tom_foreman
You need to list what year Aerostar. It makes a difference. Different year = different dash. Also is it a floor shifter or a column?
Old Mar 26, 2004 | 12:43 PM
pollok's Avatar
pollok
the year is a 91 aerostar and yes its the floor shifter
Old Mar 26, 2004 | 03:03 PM
aerocolorado's Avatar
aerocolorado
You have to carefully pry off the rectangular plastic trim piece. Underneath is a screw holding a plastic cover in place over the light bulb. Remove that to replace the bulb.
The metal portion, the forward section, of the dash can be removed fairly easily but you need a stubby Phillips screwdriver or an offset ratchet screwdriver to reach the 4 screws along the windshield side. It has been awhile since I did this but if I recall, to remove the "doghouse" section over the instrument cluster, you only need to remove the two screws on either side of the steering column and the two on the backside of the "doghouse". You do NOT need to remove the two instrument "pods" - washer/wiper and heater controls You pull the doghouse off to expose 4 other screws holding the dash cover in place. (The '91 and earlier models are so easy to get under dash access compared to later models with the one-piece dash covers.) The speakers are easily accessed at this point.
Good luck!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
