410 carb recommendation
Old Mar 25, 2004 | 07:22 PM
tastyklair's Avatar
tastyklair
I got my engine in and running. 410 ci, 8.7:1 cr, crane cam with a 2000-6000 powerband, headers, edelbrock performer, and a 600 edelbrock carb. 350 gears and 33" tires. Now I have not messed with the carb yet but upon driving it seems evident it's really starving. I will probably get one of the kits they have to try to fine tune it but I'm wondering if it's enough carb. It's stictly an occasional street driver. No mudding. I don't think I'll be try to twist 6000 out of it either, but probably 5000.
Old Mar 25, 2004 | 07:44 PM
danlee's Avatar
danlee
Yes, that should be enough carb. It is almost perfect for your stated aim. Double check for vacuum leaks, look at the color of your plugs. If lean go one step rich in cruise mode. I assume that the problem is when you are cruising.
Old Mar 25, 2004 | 11:14 PM
There Goes The Neighborhood's Avatar
For a street driver, I would recommend a Holley 650 DP, as opposed to the Edelbrock. It will have similar throttle response and a hair more top end.
Old Mar 26, 2004 | 10:13 AM
beartracks's Avatar
beartracks
I'd go with a 750 Holley or maybe 650 Demon (flow more than 650). The 650 doesn't seem to cut it when I tried it and I'm not an Edlebrock fan.
Old Mar 26, 2004 | 10:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have an Edelbrock #1406 600cfm carb on my stock 400 and I like it for the street.
