Problem with new exhaust
Old Mar 25, 2004 | 07:04 PM
cptslewis's Avatar
cptslewis
Alright guys need some help on this one... Got a 98 f150 4.6 i got the vehicle and added a KN FIPK i then followed that by removing all four catalytic converters and moving to a single in dual out Flowmaster... I got no codes for a year and a half and the truck drove perfectly. 3 months ago one of the welds broke so i was getting alot of sound and carbon and finally after driving around with it like that for a month i got a code I dont remember what number it was but i believe it said bank one sensor to lean. I then did the following mods Gibson headers and a custom built 2 1/4 in exhaust going into a dual in dual out Flowmaster. I also decided to go with two OBD ii O2 bypass on the two downstream sensors. I removed the 0bd 11 bypass and reset the computer and still got these codes.
PO 136 Downstream heated 02 sensor fault bank 1
PO 156 downstream heated 02 sensor fault bank 2
Any ideas? Do i just need to replace the 02 I looked at them with the Scanner and they seem to be operating in the right voltage range. The bank two sensor was really slow though Im assuming thats the pass side. And yes i do realize that they will read slower then the front. Also if i replace the 02 can i go with an aftermarket maybe bosch or borg warner brand or should i stick with motorcraft?
Also just out of curiosity anybody can figure out why i didnt get a catalytic convertor out of spec code?????
Old Mar 25, 2004 | 07:18 PM
the_hetz's Avatar
the_hetz
Old Mar 26, 2004 | 02:10 AM
akford351's Avatar
akford351
Since you're not running any cats then your computer will throw codes.
Those O2 sensors are telling you computer that something isn't right... not sure why they didn't throw codes earlier.
Nothing Special
Nov 16, 2016 05:54 PM
dweave
1978 - 1996 Big Bronco
Oct 20, 2008 04:15 PM
Drizzt
3.8 & 4.2L V6
Feb 15, 2007 02:14 PM
75ford250
1997 - 2003 F150
Jan 17, 2006 07:43 AM
cptslewis
Modular V8 (4.6L, 5.4L)
Mar 29, 2004 10:21 PM
