Need Help Fast!!!
Old Mar 25, 2004 | 07:00 PM
BLAZING's Avatar
BLAZING
Need Help Fast!!!
Ok heres the deal put in a new centerforce clutch and slave cyclinder. Problem is the throw out bearing is barely touching the Psi. plate and make a noise. I have a good pedal and shifts are a little hard but not bad. My buddy told me that ford tech told him the only way to get all the air out of the lines is to take a screw driver and push the slave cyclinder back and forth with the cap off. I didn't try that but I did pump the pedal way and gravity bleed it. So any ideas? Will it hurt it to drive 400 miles tomarrow?
Old Mar 25, 2004 | 08:08 PM
ga302p's Avatar
ga302p
It should eventually bleed itsself. Keep close check on fluid level.
Old Mar 25, 2004 | 08:10 PM
BLAZING's Avatar
BLAZING
Ok but why the heck is it hitting the psi plate and will it hurt it to drive it this way?
