1978 - 1996 Big Bronco
Mystery Hose........HELP!!!!
Old Mar 25, 2004 | 06:35 PM
cbledge's Avatar
cbledge
Question Mystery Hose........HELP!!!!
I have 1993 Bronco 5.8L. I am trying to replace the hoses and water pump. Ok here's the problem. If you are looking at the pump head on you have to outlets on the left side top. The bottom outlet/inlet(?) has a hose connected to it that no one can seem to locate (advance auto/autozone) anyway the hose slides over the fitting on the pump (rubber) and has a spring clamp on it...then it runs up and over the alternator (brass) and has a fitting to bolt it to the bracket...then it runs into another rubber hose with a spring clamp on it and then into the firewall..oh I forgot to mention where the rubber hose meets the brass line it has a compressed fitting......any ideas?????HELP!!!
Old Mar 26, 2004 | 09:17 AM
cbledge's Avatar
cbledge
Thumbs up
Ok, I had to order it from Ford. It's a freaking heater hose I don't understand why the auto part stores could'nt locate it???? Anyway $20 and it's fixed. Just FYI....
