Rev limiter ideas
Old Mar 25, 2004 | 01:18 PM
KJKozak2's Avatar
KJKozak2
Rev limiter ideas
Greetings all,
How would one go about cutting out 1 spark plug on each bank of a 460?
I was talking to a guy who can make the RPM triggered switch, but what could I use to ground out the plug temporarily that wouldn't ground it all the time?
Someone mentioned cutting power to the coil, but that would kill all the plugs.
Also, what problems could I cause by grounding out a plug onve in a while?
Thanks in advance!
Kevin K.
Old Mar 25, 2004 | 01:33 PM
Spooky's Avatar
Spooky
If you want to go though all the trouble of something like that just buy a MSD rev limiter or a MSD 6, when you hit the rev limiter it will cut out every other spark plug, and then fire it on the next time around so I it doese'nt load up with fuel.
Old Mar 25, 2004 | 01:48 PM
KJKozak2's Avatar
KJKozak2
Cool. Thanks.
I'll look into those. Probably easier, too.
K.
Old Mar 25, 2004 | 11:30 PM
76hiboy's Avatar
76hiboy
msd 6al has a rev limiter that you can set what rpm you want it to cut off at.
