Coolant disappearing help
Old Mar 26, 2004 | 01:03 PM
zippy the pinhead's Avatar
zippy the pinhead
On my 4.0L '96, there are two (approx. 1") hoses which go into the firewall near the top of the passenger side of the engine compartment. They are each about one foot long. At the end of these two hoses is the heater control valve. You can see a picture of mine below.
Old Mar 26, 2004 | 04:06 PM
rangersvt04's Avatar
rangersvt04
thanks zippy for the pic. when i get in the mood i will fix it but untill then it can wait
Old Mar 26, 2004 | 05:51 PM
Rockledge's Avatar
Rockledge
That is a helpful picture.
FWIW, technicially that thing is called a "Water Diverter Valve" in case the place you go to buy it has it listed under that name...
Old Mar 27, 2004 | 07:16 AM
BassGuy's Avatar
BassGuy
Thanks so much, zippy. That's exactly where I found the mineral deposits in my '96 4.0L. I'll leave the stopleak alone and just replace that.
Old Mar 28, 2004 | 10:21 PM
mazdaford5spd1997i4's Avatar
mazdaford5spd1997i4
Post
Well, good that you foind your leak. Just be careful because my heater went first(about a week before i had to replace my heater control valve), then it wouldn't keep engine temperature(i.e. just below the C hash full time), then the engine almost went to overheat(creeping almost up to H) so if youre having heating problems your next problem could be you and your truck on the side of the road. I know for a fact(my truck is a 2.3L 1997, and my friend's is a 4.0L explorer 1995) that the valve is located in the same place and routed the same all around. Just be careful and dont hurt yourself on those clamps that Ford uses for the hoses. Also, just a note, that would probably be a good time to do yourself a radiator flush, if you have time...
Old Mar 30, 2004 | 07:17 PM
Thoth88's Avatar
Thoth88
Think I fixed 'My'roblem, had radiator hose blow on Friday night within site of my house, GOT LUCKY! It was the molded hose from the pump to the heater core. So Saturday got a ride to the checker, got 'all' new hoses; upper radiator, lower radiator and 5ft of 5/8" heater hose. I didn't realize that the blown hose was MOLDED until I went to replace it. I know I'm gonna have others railing at me but I cut the molded hose about an inch from the hole, pump side, and by passed my heater core for now. It's AZ if I want heat I'll roll down the window. Yes I used the old hose to close off the core. Since Sunday I haven't lost any fluid, and when Dec rolls around I'll get to check the core. Oh yeah I did a leak down check and it held 15psi for 5min, one of the replaced hoses had a bulge in it another a weak spot and at several of the clamps evidence of weeping.
liquidice
1997 - 2003 F150
Aug 6, 2011 09:30 PM
Trailblazed
15
Mar 29, 2008 10:51 PM
BigG'sBlueMonster
Dec 2, 2007 11:27 PM
Nitrous
Oct 8, 2006 02:07 PM
sandman1984
3.8 & 4.2L V6
Jan 15, 2004 09:21 AM
