91 E250 stalls after starting
Old Mar 24, 2004 | 08:48 PM
yjman90's Avatar
yjman90
i have a 91 E250 with the 300-6 cyl.some times after i start it it will stumble and die and some times it wont.and for the other problem,after it has idled for a while it will stumble or die when i put it in gear.you guys are great so i know some one will be able to solve my problem TIA!!!
Old Mar 24, 2004 | 09:52 PM
Slade901's Avatar
Slade901
Probably the IAC or TPS. Take out the IAC and clean it and clean the spot where the IAC goes in. TPS can't be cleaned just replace it if it is bad.
Old Mar 25, 2004 | 10:54 AM
blue_mule's Avatar
blue_mule
Cool
Here's a tip too.
Reset the computer. #1 With Engine NOT running,Turn the headlamps on, disconnect the negative battery cable. #2 Wait 15 minutes... #3 turn light switch off, reconnect negative battery cable. #4 Start Engine, let idle for 3 minutes. and U R ready to go.
BaadDawg
Sep 5, 2023 07:37 AM
spike150
21
Sep 7, 2014 09:13 PM
aerocolorado
Aerostar
13
Mar 16, 2009 10:25 PM
bkeese
Aug 22, 2005 03:04 PM
blue_mule
Dec 3, 2002 04:31 PM
