Is it true that the spare tire crank down mechanism should be operated and lubed periodically?
How often, should the spare be dropped, where exactly do you have to lube it, and with what kind of product?
How tight should it be cranked back up, and is there a scientific way of measuring it. Hand tight?
I had a flat recently and the Ford roadside assist called the Canadian Auto Club.......the driver said lube this thing or I might be sorry in the future, but he was low on details.
All i can say is that you should check the mechanism out every once in a while. I have a 99 F-150 and the cable tore and the spare tire went bouncing out from under the truck going down the road. Luckily nobody was hurt.
Thanks.
I own a truck that is from 1999 bought it in 2001, never even touched it, I guess maybe I should. If you get the info on it please lemme know!!
I had the same problem that ntwfox had. I have a 99 F-150 4x4 offroad and was backing out of the driveway and the spare just dropped because the end of the cable had rotted off. that is what I would inspect is if there is any wear or tear on the end of the cable. try to put something on the end of it so that it doesnt rust.
My father-in-law had a 97 F150 that did the same thing except he lost the spare at a stop light and drove away without it because he had no idea that it had dropped. It isnt very cheap to replace the whoe spare. Cant hurt to check it though.
I had an older explorer that had the same problem. Going on to an interstate overpass I heard a big bang and looked in the rear view mirror only to see my spare tire about 50 feet in the air. No one was behind me but the tire proceeded to bounce over the side of the bridge onto the road below. All I could picture was someone with a tire through their windshield! Luckly it didn't hit anyone, but what a scare!
Ive seen a couple cars that struck a spare tire sitting in the middle of the highway. Mucho damage.
Definitely inspect it once a year at least. They arent too terribly expensive to replace if you have any doubts about the safety of it, or sling the tire in the bed.
I did find out that dirt can get in the tube and when you put the wrench in it, it just wallows out the socket. When this happens you cannot lower the tire.
Yes it happened to me. It was not from a lack of power applied to the unit either. Too much dirt is too much dirt.
I had the dirt problem the other day too, finally manged to get the tire lowered, but had to pry off the guide tube and clean the end of the internal security key out with a pin. Might have to shove a rag in the end of the tube to keep the dirt out.
