Aerostar Ford Aerostar
less noise?
Old Mar 24, 2004 | 06:13 PM
90XLT_Silver_Bullet's Avatar
90XLT_Silver_Bullet
less noise?
i was wondering, would it be good idea, or amybe someone has already done this before, would it bea good idea to insulate the paneling, im talking take off everything inside, and then pop some insulation in there.
any thoughts or comments?
Old Mar 25, 2004 | 07:37 AM
Uncle Stumpy's Avatar
Uncle Stumpy
The paneling does have some insualtion on it from the factory (fiberglas on my '96) I pulled everything out and sprayed all the sheetmetal with RoadKill sound dampener, put in Dynamat hood liner on the hood and roof, and used Cascade floor panel barrier on the floorpan. The ride is much quieter (with the stereo off!) and I have no rattles with the stereo cranked.
This is a little expensive to do, but I already had the stuff left over from a previous project.
A really easy way to quiet down the ride cost-effectively is spray all the sheet metal with a paintable undercoating (inside and out) this also gives a measure of rust protection in crappy climates like up here in Michigan.
I suppose stuffing some pink panther in between the panels and sheet metal would work resonably well.
Old Mar 26, 2004 | 07:08 AM
90XLT_Silver_Bullet
ok, thanks, ill give it a try and then post some pics and let ya know how it goes
Old Jun 1, 2004 | 06:21 PM
rickm5's Avatar
rickm5
i found this thread under a search for insulation. i have the same question. i have my side panels out to tighten the windows which were leaking. i wonder if that spray on foam would work for insulation? you know,that expandable stuff? . i'm also redoing the back carpet with indoor-outdoor grey stuff from the hardware store. i found a roll of stuff called heat shield sound and heat barrier i'm gonna put on the metal floor, then new carpet batting, then new carpet.that should keep some road noise down. i'll be at it a while. am replacing back lift hatch struts now. my main idea was to clean the van up a little, and keep it inexpensive. ...i've been eyeing those old speakers too...but i guess i should leave them alone..... #%$$... so if you have any thoughts or words of wisdom, i'm interested. thanks!! rick
91 aerostar xl, ext. 4.0 litre 2wd
aka "the green bean" 198 thousand miles and going..........
Old Jun 4, 2004 | 07:36 AM
Uncle Stumpy
I've used the expandable stuff to stiffen blind panels in my honda (filling voids) the only problem with doing this in an aero is the fact that chassis will flex on rough roads and cause the hardened epando-foam to squeak. I would buy a roll of Pink and stuff the panels before using the expanding stuff. Probably cheaper that way as well. I would recommend using the sound/heat shielding on the roof if possible to quiet the air turbulence going over the van as the floors usually already have the foil coated cardboard/felt on the floorpan from the factory.
as for the speakers GO FOR IT!!!!!!!
Old Jun 4, 2004 | 03:54 PM
rickm5's Avatar
rickm5
i pulled out that foil board ,it had gotten all wet, so i scrapped it. i figure the foil heat shield stuff will do. thanks for the input on the can sprayfoam stuff. i guess i could spray the back of the panels..? i'll look for pink stuff. do they sell rolls of foam as opposed to bats of fiberglass? as i see it i need something that will not hold water ,not rattle or come lose....another trip to the hardware ! rick
Old Jun 4, 2004 | 06:44 PM
suprajztwenty's Avatar
suprajztwenty
hey silver, are you the one on car/sounddomain? ive seen another silver bullet on there and it didnt look too bad, i think it had a custom rear bumper too. let me know if thats you.
Old Jun 6, 2004 | 08:02 AM
90XLT_Silver_Bullet
yeah thats mine, im taking some pics very soon of the new interior and ill have my new amp and sub in there as well
:edit: not custom bumper tho, put on running boards from a 93 sport, gonna be spiffying up my rims next weekend as well :edit:
frdf250
Jun 22, 2016 07:01 AM
Resendiz
Aug 4, 2015 01:29 PM
Clem's Cousin
Apr 21, 2015 05:50 PM
jayro88
21
Sep 1, 2013 08:45 AM
JB_85F150
Nov 5, 2010 02:22 PM
